View unanswered posts | View active topics It is currently February 4th, 2026, 3:43 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 105  Next
 Make Your Own ....2CV.... 4x4
Trouble Maker
So you're alive then Pete!
Good to hear from you
All the best
Rich
www.barbour4x4.com
August 30th, 2011, 10:42 pm
Hi Rich,
Just hibernating a bit.
August 31st, 2011, 9:41 am
Some pictures of build..
GS 5 speed box being modified.
Rear end so far...
Front end with Transfer box.
September 30th, 2011, 3:05 pm
Chassis 90% complete and painted.
Heavy at 80Kg but strong(I think?)
October 30th, 2011, 1:33 pm
looks nice, great work!
October 30th, 2011, 8:59 pm
Weights So Far in kgs...........
Heavy... but its is 4x4 after all.
Rear Arm 14 Actual
Rear Arm 14 Actual
Front Arm 14 Actual
Front Arm 14 Actual
Rear Diff 40 Actual
Front Diff 40 Actual
Transfer box 20 Actual
Rear Cross Tube 09 Actual
Steering Rack 14 Actual
Spring Cans (Four) 24 Actual
Drive Shafts (Four) 22 Actual
Chassis 80 Actual
Gearbox 50 Estimate
Engine 70 Estimate
Prop Shaft 1 05 Estimate
Prop Shaft 2 05 Estimate
Prop Shaft 3 05 Estimate
Body 90 Estimate
Doors + wings +stuff 60 Estimate
Total 590 Estimate
October 31st, 2011, 4:51 pm
Total 590 Estimate
I don't want to killjoy but an original 2cv comes in at 560kg so I think 590kg is a little bit optimistic.....
My ami6 4x4 (Mehari4x4 technics) with 2 winches comes in at 840 kg
My sahara 2 times 2cv6 engine ami8 Chassis at 780kg
So when you count like this:
Original 2cv 560kg
middiv 30kg
backdiv 40kg
driveshafts 16kg
propshafts 8kg
reinforcments 45kg (chassis and body)
bigger wheels 20kg (5 times 4 kg)
So this will give you 719kg (MOT ready) (when you build it Lighter then 700kg I buy you abottle of Whisky) (my favorit 2cvWM drink as by Mark4x4)
October 31st, 2011, 7:45 pm
Guess I should look around for "Bargin's" in the Whisky department.
Can only get heaver, forgot about wheels/tyres, all large and heavy.
How about comparison of Kg's/ total number of "gear ratio's"!
October 31st, 2011, 9:09 pm
My ami has about 72/1 total reduction (2cv4 prime axle insted of dyane 6)
which gives you about 1/2 mile/hour at idle!!!!
You can release the clutchpedal without touching the throttle even on a steep slope!!! (Going up ofcours you wiseheads) :lol:
The Sahara has got two 2cv4 gearboxes and dyane 6 engines..!!!
October 31st, 2011, 9:49 pm
id love a 2cv with a massivly low ratio in first in a low range option on the box and then a normal gear 1
One of those things just for messing about, i was amazed when i drove the navara the other day when pulling a boat out (yes its a navara not a 2cv, it has a 2.5L DI engine!) how much grunt low range 1st has, it was about 2 mph but i felt like i could of pulled the tectonic plates around ;)
id love a 2cv with extra low range to pull boats out with :D
October 31st, 2011, 10:20 pm
