View unanswered posts | View active topics It is currently May 1st, 2026, 1:25 pm
Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
 Shocker Mounting Point
Post Re: Shocker Mounting Point
If broken bolt is hard to turn, use a bit of heat on the outside of the tube
January 6th, 2011, 10:47 pm
Nels,
don't forget that those damper mounting pins are made of tough material, so best to use a good quality drill bit, maybe even cobalt.
From what I've seen, a broken stud is usually the result of it having been under-tightened when the chassis was built up.
The specified torque is 150 ft.lbs.
January 6th, 2011, 10:49 pm
Thats great info but where can I buy this sort of gear - ez outs look to be feckin expensive and american
January 6th, 2011, 10:56 pm
I had this happen took 3 drill bits and still didn't fix it, so I got a new bit re welded on by richard.
January 6th, 2011, 10:58 pm
You should get EZ outs from any good local tool shop Halfrauds might do them to and some motor factors.
January 6th, 2011, 11:35 pm
EZ outs are the way to go. Clean out the mounting point with a cut up tooth brush and white spirit then put a new bolt in real tight.
Mine went through a spate of throwing shock absorbers :lol:
All 9 pages of the saga(s)
http://www.international2cvfriends.com/forum/viewtopic.php?f=7&t=1926&hilit=fell+off
January 7th, 2011, 1:17 am
Users browsing this forum: No registered users and 103 guests
