View unanswered posts | View active topics It is currently May 7th, 2026, 8:43 pm
Reply to topic  [ 348 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 35  Next
 My Beduino
Post Re: My Beduino
These ones, I suppose there's a spring inside, so they are tensioned by a spring?
https://www.paddockspares.com/miltary-and-series-bonnet-fastener-catch-pair.html
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
September 22nd, 2018, 5:01 pm
Post Re: My Beduino
I do rather like that one Eirikj. :)
However, I would still like to find a mechanism to operate from inside the car.
I'm considering dzus 1/4 turn, but am not sure they are strong enough. I have a pair and will see if they may fit. I need to buy the correct rear spring bits first.
These aren't the ones I have, but I do have ring ones.
September 22nd, 2018, 8:05 pm
Post Re: My Beduino
I didn't mean you should use the ones I liked to, I just was curious how they work, as it's not mentioned in any of the ads. And if they are spring loaded, I might have use for them.
The ones you linked to are common on motorcycles. Fairings and stuff like that. They are great for that use, but to secure a fender, or a whole front end... No. Too weak.
September 23rd, 2018, 12:57 am
Post Re: My Beduino
The military land rover catch does have a spring as you suggest. It's pivoted at one end and you just pull and hook it on to the other bit. Not easy to see in the image.
I like the look and simplicity. :)
September 23rd, 2018, 3:58 am
Post Re: My Beduino
As the bulkhead is flat and vertical ??,
How about a boot/bonnet catch
(without wires)
eng_pm_BONNET-LATCH-LOCKHOOK-CATCH-VW-SHARAN-ALHAMBRA-7N1823509A-26468_1.jpg [ 83.98 KiB | Viewed 10487 times ]
September 23rd, 2018, 9:30 am
Post Re: My Beduino
Hi Pete
Its not vertical. So there is a shearing action as the bonnet (wing) closes.
Talking with you guys has made me realise that I will have to close it and then insert the fastener in. That, or enlongate the holes, but that adds the issue of water getting in. Though a closed cell sponge pad may sort that!
Its good to talk. :D
September 23rd, 2018, 11:45 am
Post Re: My Beduino
Maybe a boot/bonnet catch is a good idea. You can just mount the lock in an angle so there is no shearing action, yes? And a release handle inside the car, connected with a wire. And some sort of back up solution would probably be smart ;)
September 24th, 2018, 9:40 pm
Post Re: My Beduino
I made the castle nut tool for suspension arm's. :)
Not very durable, but got them on.
September 28th, 2018, 8:14 am
Post Re: My Beduino
Epic 8-) .
September 28th, 2018, 9:15 am
Post Re: My Beduino
Crackin'! 8-)
Mike
September 28th, 2018, 2:21 pm
Users browsing this forum: No registered users and 324 guests
