EirikJ
 Re: My Beduino
These ones, I suppose there's a spring inside, so they are tensioned by a spring? https://www.paddockspares.com/miltary-and-series-bonnet-fastener-catch-pair.html
| September 22nd, 2018, 5:01 pm |
Roger V
 Re: My Beduino
I do rather like that one Eirikj. However, I would still like to find a mechanism to operate from inside the car. I'm considering dzus 1/4 turn, but am not sure they are strong enough. I have a pair and will see if they may fit. I need to buy the correct rear spring bits first. These aren't the ones I have, but I do have ring ones.
| September 22nd, 2018, 8:05 pm |
EirikJ
 Re: My Beduino
I didn't mean you should use the ones I liked to, I just was curious how they work, as it's not mentioned in any of the ads. And if they are spring loaded, I might have use for them.
The ones you linked to are common on motorcycles. Fairings and stuff like that. They are great for that use, but to secure a fender, or a whole front end... No. Too weak.
| September 23rd, 2018, 12:57 am |
Roger V
 Re: My Beduino
The military land rover catch does have a spring as you suggest. It's pivoted at one end and you just pull and hook it on to the other bit. Not easy to see in the image. I like the look and simplicity.
| September 23rd, 2018, 3:58 am |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2254 Location: Near Monmouth
 Re: My Beduino
As the bulkhead is flat and vertical ??, How about a boot/bonnet catch (without wires) Attachment:
eng_pm_BONNET-LATCH-LOCKHOOK-CATCH-VW-SHARAN-ALHAMBRA-7N1823509A-26468_1.jpg [ 83.98 KiB | Viewed 10488 times ]
| September 23rd, 2018, 9:30 am |
Roger V
 Re: My Beduino
Hi Pete Its not vertical. So there is a shearing action as the bonnet (wing) closes. Talking with you guys has made me realise that I will have to close it and then insert the fastener in. That, or enlongate the holes, but that adds the issue of water getting in. Though a closed cell sponge pad may sort that! Its good to talk.
| September 23rd, 2018, 11:45 am |
EirikJ
 Re: My Beduino
Maybe a boot/bonnet catch is a good idea. You can just mount the lock in an angle so there is no shearing action, yes? And a release handle inside the car, connected with a wire. And some sort of back up solution would probably be smart
| September 24th, 2018, 9:40 pm |
Roger V
 Re: My Beduino
I made the castle nut tool for suspension arm's. Not very durable, but got them on.
| September 28th, 2018, 8:14 am |
rob massey55
 Re: My Beduino
Epic  .
| September 28th, 2018, 9:15 am |
citroenboat
 Re: My Beduino
Crackin'!
_________________ Mike
| September 28th, 2018, 2:21 pm |
Users browsing this forum: No registered users and 326 guests |
