View unanswered posts | View active topics It is currently June 28th, 2025, 7:32 am
 Which (if any) electronic ignition
Post Re: Which (if any) electronic ignition
Ayjay mentioned "a yellow Harley coil" is this from the Harley Davidson? Is this a good upgrade? Is it simply a plug and play application? If so I may consider if it gives a stronger spark
1972 dyane4 435cc
November 15th, 2012, 10:35 pm
When you stay with point, stay with the original coil too, it has worked for over 60 years now...... You just need to turn the ignition off asap when the engine doesn't run thats all..
So don't listen to your radio for instance with contact on. It can/will burn your coil or points..
November 15th, 2012, 10:41 pm
It usually means no put together or built very well,
The dictionary defines bodge as,1. to make a mess of
2. to make or adjust in a false or clumsy way: I bodged the figures up.
Hope that explains it a bit better ipgo.
Dyane 12 1976 (ish)
November 15th, 2012, 10:55 pm
So totaly of topic but it's LPGO my cars run on LPG and my name is Geo.....
and thanks for the explanation will read the post again...
November 15th, 2012, 10:59 pm
Nels,
are you sure you don't mean a 'points assisted' setup, of which capacitve discharge were just one type?
I've been using Boyer Bransden's little ID units for many years, with a set of points often lasting over 100,000 miles...
Nelsthebass wrote:
You could always add a capacitor discharge ignition to the points if you don't want to strip it down - prolongs points life and gives a big juicy spark - not many places do them but you could try a motorcycle shop rather than go for the expensive Boyer ones - good old fashioned sparkrite etc
November 15th, 2012, 11:00 pm
How many miles did you do on total then?????
November 15th, 2012, 11:07 pm
Thats genius !! lpgo!!
November 15th, 2012, 11:15 pm
Sorry geo,
that was my iPad trying to correct my spelling before I finished the word or making up its own words if it doesn't recognise a word, trying to be to clever for its own good!!!
Dyane 12 1976 (ish)
November 15th, 2012, 11:16 pm
ken wrote:
Nels,
I may one day invest in a boyer, maybe my points will last more than 3k!!
speak to gina at boyer she will sort you out around 40 delievered iirc
November 15th, 2012, 11:17 pm
Are these Boyer bransden units hard to come by? Had a quick google but couldn't find a supplier
1972 dyane4 435cc
November 15th, 2012, 11:23 pm
