Author |
Rumble602
Joined: January 26th, 2009, 10:16 pm Posts: 1074 Location: Derbyshire
 Re: In-car Tunes
OK - I've opened the box!! Huge cable included. Audio side of install looks dead easy.
Just a question about power feeds. I'd like to be able to switch the sub on/off with a switch seperate to the head unit. Any advice on how to wire in the power control feed would be ace. Manual suggests using the accesory line of the ignition - but obviously, I'd like to run it without the ignition on!
Ta!
May 28th, 2009, 5:11 pm |
Will2cv
 Re: In-car Tunes
Probably simplest to connect the remote power on feed to your electric aerial supply as you did your other amp, but put an in-line switch in so you can flick it on and off.
1979 2cv6 (Evie) 1983 Beachcomber (Mavis) 1974 AZU250 Belgian PO (The van) 1991 AXGT Mk1 2008 C5 2.0 HDi VTR+
May 28th, 2009, 6:12 pm |
Rumble602
 Re: In-car Tunes
Ok, sounds easy enough then. Will any on/off switch do the job?
May 28th, 2009, 9:55 pm |
Will2cv
 Re: In-car Tunes
Yup just a simple rocker switch or summat should do, positioned in a place of your choice!
May 29th, 2009, 5:18 pm |
Rumble602
 Re: In-car Tunes
Well, I've fitted the sub - still got to attach the wires what make it noisy.
It fits under the rear seat OK untill someone sits on it! So, it's mounted vertically in the boot behing the seat facing into the car. Takes up a bit of boot space, but hey ho never mind.
Sunday should see wiring in completed. umpf umpf umpf
May 29th, 2009, 11:52 pm |
Rumble602
 Re: In-car Tunes
Install completed! Umpf Umpf Umpf sounds ace with House Music. Thanks for the help and advice guys.
Spent rest of day T-cutting several years of oxidisation back to find a Myo Blue car underneath!
May 31st, 2009, 9:23 pm |
Neil
 Re: In-car Tunes
Rumble602 wrote: Spent rest of day T-cutting several years of oxidisation back to find a Myo Blue car underneath!
nice, any pics?
May 31st, 2009, 10:12 pm |
Rumble602
 Re: In-car Tunes
Tomorrow, after a waxing.
May 31st, 2009, 10:28 pm |
Neil
 Re: In-car Tunes
Rumble602 wrote: Tomorrow, after a waxing. i meant J, not you!
May 31st, 2009, 10:42 pm |
Rumble602
 Re: In-car Tunes
Bugger. I'll take some of J tomorrow then.
June 2nd, 2009, 12:36 am |
Users browsing this forum: No registered users and 56 guests |
