View unanswered posts | View active topics It is currently August 13th, 2025, 4:28 am
Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3, 4
 In-car Tunes
Post Re: In-car Tunes
OK - I've opened the box!! Huge cable included. Audio side of install looks dead easy.
Just a question about power feeds. I'd like to be able to switch the sub on/off with a switch seperate to the head unit. Any advice on how to wire in the power control feed would be ace. Manual suggests using the accesory line of the ignition - but obviously, I'd like to run it without the ignition on!
Ta!
May 28th, 2009, 5:11 pm
Probably simplest to connect the remote power on feed to your electric aerial supply as you did your other amp, but put an in-line switch in so you can flick it on and off.
1979 2cv6 (Evie)
1983 Beachcomber (Mavis)
1991 AXGT Mk1
2008 C5 2.0 HDi VTR+
May 28th, 2009, 6:12 pm
Ok, sounds easy enough then. Will any on/off switch do the job?
May 28th, 2009, 9:55 pm
Yup just a simple rocker switch or summat should do, positioned in a place of your choice!
1979 2cv6 (Evie)
1991 AXGT Mk1
May 29th, 2009, 5:18 pm
Well, I've fitted the sub - still got to attach the wires what make it noisy.
It fits under the rear seat OK untill someone sits on it! So, it's mounted vertically in the boot behing the seat facing into the car. Takes up a bit of boot space, but hey ho never mind.
Sunday should see wiring in completed. umpf umpf umpf
May 29th, 2009, 11:52 pm
Install completed! Umpf Umpf Umpf sounds ace with House Music. Thanks for the help and advice guys.
Spent rest of day T-cutting several years of oxidisation back to find a Myo Blue car underneath!
May 31st, 2009, 9:23 pm
nice, any pics? ;)
May 31st, 2009, 10:12 pm
Tomorrow, after a waxing.
May 31st, 2009, 10:28 pm
i meant J, not you! ;) :lol:
May 31st, 2009, 10:42 pm
Bugger. I'll take some of J tomorrow then.
June 2nd, 2009, 12:36 am
