View unanswered posts | View active topics It is currently May 2nd, 2026, 2:16 am
 Driveshaft Boots
Post Driveshaft Boots
Hi all,
i have a split boot on my driveshaft.Just wondering how quck do i need to get it fixed.
Thanks.
June 16th, 2011, 12:30 pm
Post Re: Driveshaft Boots
Immediately, if not sooner.
June 16th, 2011, 12:38 pm
Thanks,will get it sorted.
June 16th, 2011, 12:41 pm
sew it with cotton and needle till the new one arrives in the post ;)
June 16th, 2011, 8:45 pm
There was a small split in one of mine. I cleaned it thoroughly, roughened the surface with fine wet & dry, then sealed with Evostik metal bond which stays flexible. It has lasted over a year so far. Passed MOT no problem.
John Jordan
June 16th, 2011, 9:55 pm
Nice tip, Knightley! Did you butt-join the edges or overlap them slightly? Does Evostik metal bond have a specific name, or is it just that? Ta.
June 16th, 2011, 11:20 pm
I put on a blob which covered the split (butt join), so it looks like a small grey slug on the boot. You could put a bit of superglue in the slit first. I can't remember if I did that. (I have in the past on previous cars and it held)
It is called Evostik Liquid Metal.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_176487_langId_-1_categoryId_165691
John Jordan
June 16th, 2011, 11:33 pm
matt damper put a bycycle patch on my boot, as it had a hole in it, and wanted to stop dirt getting in !
June 17th, 2011, 12:55 am
I think it's not to prevent dirt getting in it, but keeping the grease in..
June 17th, 2011, 11:22 am
...and keep water out ;)
Hmmm, this stuff "...bonds metals...almost as strong as welding..." 8-)
June 17th, 2011, 11:34 am
Users browsing this forum: No registered users and 151 guests
