View unanswered posts | View active topics It is currently July 4th, 2025, 8:24 am
Reply to topic  [ 66 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
 Oil - Everywhere. Smoke too!
Post Re: Oil - Everywhere. Smoke too!
dave 411 wrote:
Maybe the bolt is bottoming out (too long)?
Is there a gasket or seal that may have blown?
Your nuts will be with you next week,tues/wed.
Cheers :) thank you!!
Rekon its probably the gasket so
I'd tap it m8 and use a new gasket.
is the way to go.
May 21st, 2011, 9:51 am
Have you done a compression test and made sure it hasn't snapped a ring?
I've got a big M4 reniflard if you want to try that.
May 21st, 2011, 10:50 am
I thought it might have got worn rings as it smokes like dot cotton. I don't have a compression tester unfortunately.
May 21st, 2011, 10:59 am
Would that cause it to pee out of the filler gasket? Just tried to drive to work, but it was pouring out by the gasket that seals between the filler and crank case.
I'll get a new gasket and go for the thread insert option.
How do I do a compression test?
May 21st, 2011, 11:01 am
There's a thread on compression testing here:
viewtopic.php?f=7&t=2789&hilit=compression+test :lol:
May 21st, 2011, 11:13 am
You want something like eBay item 250689979901.
May 21st, 2011, 11:16 am
If a ring is broken then the compression created as the piston goes up the bore leaks past the pistonj and pressurises the crank case. That in turn can cause the oil to leak out all over the place.
The gasket between the crank case and rebiflard ought to withstand that though. Have you put a straight edge across the flange on the reniflard to see if it isn't warped?
May 22nd, 2011, 1:31 am
Whats a reniflard :?:
May 22nd, 2011, 7:57 am
French for breather i believe :P
The oil filler fandango with the pipe coming off to the airbox, bolts on the crank case with two bolts .
May 22nd, 2011, 8:41 am
Ah,thanks :)
May 22nd, 2011, 9:22 am
