View unanswered posts | View active topics It is currently November 21st, 2025, 9:26 am
 M4 Engine questions and advice.
Post Re: M4 Engine questions and advice.
Russell,
probably worth removing that sheet metal plate behind the points box to see if there's any evidence of the advance mechanism dragging on it, which often happens if the points box securing bolts have been over-tightened.
If that's not the problem, time to check the condition of the advance weights... :(
I'd have thought that the engine would be pretty gutless, with the timing at higher rpm so retarded.
May 10th, 2011, 9:56 pm
May 10th, 2011, 10:04 pm
Oddly enough it seemed to go quite well, I will have a look at the weights again another day. I took that plate off and it didn't appear that anything had hit it or been in contact with it.
May 10th, 2011, 10:06 pm
Van goes really well. It actually ticks over now which is a massive development :D I'm really quite impressed at how given a good tune it really seems to go ok.
May 11th, 2011, 12:23 am
sam,
I guess ticking over properly is a good start, but if it's only advancing 3 teeth from the static timing position, that's 22* total, so there's a risk of overheating if it's worked hard.
It _will_ go much better with the ignition advance working correctly... ;)
May 11th, 2011, 12:52 am
There may have been no evidence of the advance dragging on the plate in the past but what's happening since you screwed it all back is what you need to worry about.
the other thing is that if you use one of the cover screws or even the condenser side screw, for the fixed part of the points they can drag on the cam too
You havn't done something silly like put the bob weights on back to front or the cam in the wrong way?
dont ask :oops:
May be an instance when a new set of weights is needed :lol:
May 11th, 2011, 8:59 am
Sam didn't take my advice which was rip the pox thing out and put a nice D*lly engine in and a disc box.
Sam, I have a "recent" engine that I dont need. Its hung around for a bit and I know nothing of its history, but its all there and if it helps or bits of it help get in touch. I am going to stick it in the flea market bit anyway.
May 11th, 2011, 8:31 pm
I've no idea why I'm saying this, is it complete with ancillaries? I'm interested.
FFS.
May 11th, 2011, 9:44 pm
Hi Russell,
I honestly cant remember and its now dark so I cant check...ask James he has seen it, and I will look tommorrow and post description and a pic.
...but its one I got from the hut as a "spare" I never needed ....quality is of that nature !
Be back to you !
'box
May 11th, 2011, 10:08 pm
yes complete as far as i remeber with heat exchanger too
May 12th, 2011, 11:12 pm
