View unanswered posts | View active topics It is currently July 2nd, 2025, 10:53 pm
 Breather Overhall
Post Re: Breather Overhall
Old engine with Pistons/Barrels at some point.
Before - no vacuum at tickover, same at high rpm .
After - 4.5cm vacuum at tickover 0 at high rpm.
Moving in the right direction....
For the DIY members...... make a manometer, measure from dipstick pipe and report back.
April 21st, 2011, 10:55 am
Clearly!
Maybe works perfect on a good engine then :)
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
April 21st, 2011, 11:12 am
Is that a request for data?
last breather I overhauled had 4cm at 5Krpm
and sucked up the lhm at fast tickover
have found other diapragm material and will try varying thickness, dont want it sucking too hard as that would defeat the purpose.....may sell the idea to Mr Dyson.
April 21st, 2011, 11:41 am
Thanks Sean
So far only replaced the "flap valve" in the middle.
Vitron is the stuff
http://www.rhnuttall.co.uk/Materials/Ru ... ubber.html
April 21st, 2011, 12:24 pm
silicone rubber myself, cheap and has a sealing side that's glassy smooth
just have to wait for more baking trays to tun up in TK Maxx :lol:
( oil and grease proof, un affected by temperatures up to 250C-and if i gets that hot its not your breather you need to be worrying about.)
April 21st, 2011, 1:44 pm
Baking trays? Tell us more...
April 22nd, 2011, 1:07 am
Silicone baking sheets,not really trays.
April 22nd, 2011, 7:34 am
"tins"
you get all sorts of thickness you just have to be patient and rake about
April 22nd, 2011, 8:46 am
WHOOPS :oops:
April 24th, 2011, 8:56 pm
'Silicone'? Do you mean Teflon-coated steel? Hmmmm, interesting...... :)
April 25th, 2011, 1:34 pm
