View unanswered posts | View active topics It is currently May 1st, 2026, 11:23 pm
Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3, 4
 Engine compression
Post Re: Engine compression
A bit OT, but I just watched a man time his car up 180 degrees out. It didn't have much compression. I laughed.
it would have had...but just at the wrong time ;)
March 17th, 2011, 9:41 pm
Can we debate leak down testing now......... :ugeek:
March 17th, 2011, 9:55 pm
Is that on a cold engine, hot engine or just warm and cuddly?
March 17th, 2011, 10:32 pm
'Throttle wide open' or 'throttle closed' is the one which really makes a difference...
At close of play today, decided to do a few tests on an engine, using all possible combinations of hot/cold/open or closed throttle.
CBA to write it all out now, as I need to get to the pub and try to spend some 'funny money' which was sent from North of the border, but the readings are about 30 to 40 psi lower if you forget to press the throttle pedal down. :lol:
( p.s. Leak down testing is undoubtedly a far better diagnostic tool than a simple compression test. )
March 17th, 2011, 11:34 pm
well if they dont take it against some Guinness today of all days send it back :P
March 17th, 2011, 11:53 pm
well most technicians pressurise the bore via an adaptor in the spark plug hole
but as most insn't necessarily correct we could put it up the exhaust pipe :mrgreen:
(Im in the process of making a crude one from a schrader valve and an old sparkplug and a tyre inflater with a gauge .....
sticky black plastic and Vals old knickers optional :lol: )
March 18th, 2011, 12:04 am
I don't start these threads to cause arguments, honest
watch this clip with the sound up and all your niggles will fade away
http://trololololololololololo.com
(totally work safe bytheway)
:lol:
March 18th, 2011, 3:52 pm
:lol:
That is indeed very funny. Must be a Eurovision winner at least. :lol: :lol: :lol:
March 18th, 2011, 4:42 pm
Users browsing this forum: No registered users and 118 guests
