View unanswered posts | View active topics It is currently April 29th, 2026, 2:59 pm
Reply to topic  [ 27 posts ]  Go to page Previous  1, 2, 3
 Electronic Ignition.. what type should I go for?
Post Re: Electronic Ignition.. what type should I go for?
Luke wrote:
Very interesting stuff! I think I know where I'd be able to get my hands on a PIC programmer as well..! Interesting that the older version of the circuit had a capacitor across the transistor, whereas the newer one doesn't seem to. Or is that just due to the different transistor? My French is awful - was there a link on the site to any photos of how they've installed it all?
At the side with the older version there's a pcb layout, (french typon) but I can't match it with the schema...... I can't find any pictures either, but when I see other layouts I think it works. Yesterday evening downloaded software to programm a pic, but run out of time....
In my imagination I've already made my own efi!!!!! :lol: :lol: :lol:
January 31st, 2011, 1:14 pm
Bargain?
http://cgi.ebay.co.uk/2cv-electronic-ignition-/260730657407?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cb4c21a7f
January 31st, 2011, 10:18 pm
My car's fitted with a DG. It's been absolutely great. I'd say £50 is a very good price (although you always take a bit of a flyer with ebay... caveat emptor and all that...)
January 31st, 2011, 10:24 pm
jut got a "sparkrite" off the on line tat emporium
Hmm definitley designed in the days when electronics was not to be trusted and bigger was most deff. better! Its HUGE and heavy( has a massive ballast weight) and when you pull the thing to bits all it is is a big impressive finned ally box containing a bit bigger than credit card sized PCB- even that could have been halved, each track is separated by at least 4mm of blank board-all doing the same as the much more compact Vellerman kit. Ok so it has a back to points switch(why?-legacy of the "dont trust electronic" days) and a timing light-which is where Vellerman looses out.
of the 3 points assist kits Boyer now gets my vote.
who wants a sparkrite sx1000 kit, still boxed with all fitting bits and instructions? £20 ish inc postage would be a fab retro gizmo for a champagne coloured Viva or the like:D
February 1st, 2011, 3:18 pm
That link from Lenny was a real bargain - 3 happy 2CV owners out there!
Sean, yes they are big fellas, them Sparkrites. Fine for most big ugly heavy cars, but a tad crude for us delicate 2CV types. That's why I've tended to go for the 'TT' model - designed especially for motorbikes, but they work just as well in cars. They are really neat - about 2" x 1.5" x 1.5".
I fitted one to my very first car 30 years ago - a Dutton Melos I built myself. You could buy the units from Halfords these days. My last pre-2CV car - a Marlin - also had one fitted, care of eBay.
I now have another one ready for my 2CV - as soon as it's put back on the road.
Do you not think your SX1000 is still worth fitting? Why do you think the Boyer is better - or is it just size?
(Yes, the change-over switch was very much a 'just in case'...!)
February 1st, 2011, 11:28 pm
yup pretty much
Sparky too big and heavy for what is just a credit card sized PCB
Velleman kit-need to add box and has no timing light
so boyer_small, rugged, fully waterproof and timing light
timing light not essential but allows you to check thet the points heel hasnt worn and moved the timing - and makes the initial setup a doddle
and if it all stops at the side of the road you can see the iggy not at fault
sparky tt set up
more points assist options
February 2nd, 2011, 10:31 am
Rumble602 wrote:
Blimey. I went cross eyed at all that technical stuff. I'm running 123. It's been fine for years, but has done nothing for my fuel economy. Can I tell the difference between 123 and points when driving? No, I can't. But then i can't tell one type of spark plug from another. If it starts, and runs then all is good in my book.
It's not just me then!
+1..'cept the spark plug bit, i do know my plug types :P
February 2nd, 2011, 11:38 am
