View unanswered posts | View active topics It is currently April 29th, 2026, 2:59 pm
Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 9  Next
 Battery Cables, + fuel pipe question all in one go
Post Re: Battery Cables, + fuel pipe question all in one go
Jameswallace wrote:
hmm
just seems im being attacked from all angles
That should give you some clue as to what a daft idea it was spending the same amount as a correctly sized battery would have cost on something that's not designed to fit. Cut your losses, sell the thing to someone with a tractor and buy a proper battery. Don't go f**king about trying to fit it under the seats - as others have said, this is dangerous - or whatever. You're making problems where none existed.
Last edited by Rhythm Thief on December 2nd, 2010, 9:25 pm, edited 1 time in total.
December 2nd, 2010, 9:23 pm
Besides, if you'd mentioned it I could have sent you the battery from my old Charleston for the cost of the postage.
December 2nd, 2010, 9:24 pm
Jonathan,
true, but I reckon that the reason why bulkheads crack on RHD cars lies elsewhere.
Citroen relocated the battery box from where it sits on LHD cars, moving it further down and towards the nearside, but didn't bother to relocate the strengthening plate which they'd used on LHD cars.
For some years, they did provide a little support bracket which was bolted onto the bulkhead, but when that was ditched...
Perishing accountants, yet again. :roll:
Jonathan wrote:
James, the 2cv had a 6v electrical system up until '69/70, and a 6v battery is much smaller then a 12v battery, so even with a standard 12v 063 battery fitted, you're putting too much strain on the bulkhead.
ive taken the springs out (lost one now :roll: and then tied a piece of string to the ends and to the frame as a tempoary solution, i will make my own rods up asap,
ill go down to homebase (need to go anyway) in the next few days, as well as lidl to get that jack there apparently doing and see if i can get it there
rt the battery is only longer
erm
let me try and draw one on here
.. ___ ____
the hight is the same |__| |___|
youll have to use your imagination with that drawing, im prospective its not even much longer than my detailed (ha) drawing would show,
imagine that as looking at the side of the battery with normally a label on it
make sense?
thanks for the offer RT, but lifes full of "could of's" ;)
never mind :D
December 2nd, 2010, 9:28 pm
ken wrote:
Jonathan,
ken a friend of mine worked in the rolls factory in good wood, they all sat down and said, "what we need round here, is more clipboards, and more people with them"
typical, money before praticality / sensibility / common sense as per usual
December 2nd, 2010, 9:31 pm
Exactly. As I said, it's not designed to fit. Haven't you also created an issue with the bonnet stay shorting out the terminals?
December 2nd, 2010, 9:32 pm
[quote="ken"]
hmm just sits so nice on the parcel shelf and nestled into the back of the "binnacle"
often thought of trying to replicate that on rhd
sean
December 2nd, 2010, 9:34 pm
Jameswallace wrote:
well it currently fits, as it is
Yes, James, it fits perfectly. Apart from the cables, the bonnet support, the retainers, the extra weight, the length overhanging the tray...
December 2nd, 2010, 9:36 pm
yer true, i could turn the battery round but it would probably put tension in the cables
ill sort it
i know ive created problems but i will solve these problems
now, ive mever understood bolts etc, i get it when its in mm and inches, but what does it mean by m8, i know thats 8mm cos it says, but why m8??
i found this bar, going to make my own up
http://cgi.ebay.co.uk/STAINLESS-STEEL-M8-8MM-THREADED-BAR-ROD-STUDDING-100mm-/270651820109?pt=UK_DIY_Material_Nails_Fixing_MJ&hash=item3f041b084d
December 2nd, 2010, 9:37 pm
so whats the fuel pipe question?
December 2nd, 2010, 9:39 pm
