Battery Cables, + fuel pipe question all in one go
Rhythm Thief
Joined: March 10th, 2010, 12:37 am Posts: 1927 Location: Alone in my polytunnel with my pitiful competition onions
 Re: Battery Cables, + fuel pipe question all in one go
Jameswallace wrote: hmm
just seems im being attacked from all angles
That should give you some clue as to what a daft idea it was spending the same amount as a correctly sized battery would have cost on something that's not designed to fit. Cut your losses, sell the thing to someone with a tractor and buy a proper battery. Don't go f**king about trying to fit it under the seats - as others have said, this is dangerous - or whatever. You're making problems where none existed.
_________________ The best things in life aren't things.
Last edited by Rhythm Thief on December 2nd, 2010, 9:25 pm, edited 1 time in total.
| December 2nd, 2010, 9:23 pm |
Rhythm Thief
Besides, if you'd mentioned it I could have sent you the battery from my old Charleston for the cost of the postage.
| December 2nd, 2010, 9:24 pm |
Jonathan, true, but I reckon that the reason why bulkheads crack on RHD cars lies elsewhere. Citroen relocated the battery box from where it sits on LHD cars, moving it further down and towards the nearside, but didn't bother to relocate the strengthening plate which they'd used on LHD cars. For some years, they did provide a little support bracket which was bolted onto the bulkhead, but when that was ditched... Perishing accountants, yet again. ken. Jonathan wrote: James, the 2cv had a 6v electrical system up until '69/70, and a 6v battery is much smaller then a 12v battery, so even with a standard 12v 063 battery fitted, you're putting too much strain on the bulkhead.
| December 2nd, 2010, 9:25 pm |
J-dub
ive taken the springs out (lost one now  and then tied a piece of string to the ends and to the frame as a tempoary solution, i will make my own rods up asap, ill go down to homebase (need to go anyway) in the next few days, as well as lidl to get that jack there apparently doing and see if i can get it there rt the battery is only longer erm let me try and draw one on here .. ___ ____ the hight is the same |__| |___| youll have to use your imagination with that drawing, im prospective its not even much longer than my detailed (ha) drawing would show, imagine that as looking at the side of the battery with normally a label on it make sense? thanks for the offer RT, but lifes full of "could of's"  never mind
| December 2nd, 2010, 9:28 pm |
J-dub
ken wrote: Jonathan, true, but I reckon that the reason why bulkheads crack on RHD cars lies elsewhere. Citroen relocated the battery box from where it sits on LHD cars, moving it further down and towards the nearside, but didn't bother to relocate the strengthening plate which they'd used on LHD cars. For some years, they did provide a little support bracket which was bolted onto the bulkhead, but when that was ditched... Perishing accountants, yet again. ken. Jonathan wrote: James, the 2cv had a 6v electrical system up until '69/70, and a 6v battery is much smaller then a 12v battery, so even with a standard 12v 063 battery fitted, you're putting too much strain on the bulkhead. ken a friend of mine worked in the rolls factory in good wood, they all sat down and said, "what we need round here, is more clipboards, and more people with them" typical, money before praticality / sensibility / common sense as per usual
| December 2nd, 2010, 9:31 pm |
Rhythm Thief
Jameswallace wrote: rt the battery is only longer
Exactly. As I said, it's not designed to fit. Haven't you also created an issue with the bonnet stay shorting out the terminals?
| December 2nd, 2010, 9:32 pm |
[quote="ken"]
Citroen relocated the battery box from where it sits on LHD cars, moving it further down and towards the nearside, but didn't bother to relocate the strengthening plate which they'd used on LHD cars. ken.
hmm just sits so nice on the parcel shelf and nestled into the back of the "binnacle"
often thought of trying to replicate that on rhd
sean
| December 2nd, 2010, 9:34 pm |
toomany2cvs
Jameswallace wrote: well it currently fits, as it is Yes, James, it fits perfectly. Apart from the cables, the bonnet support, the retainers, the extra weight, the length overhanging the tray...
| December 2nd, 2010, 9:36 pm |
J-dub
Rhythm Thief wrote: Jameswallace wrote: rt the battery is only longer
Exactly. As I said, it's not designed to fit. Haven't you also created an issue with the bonnet stay shorting out the terminals? yer true, i could turn the battery round but it would probably put tension in the cables ill sort it i know ive created problems but i will solve these problems now, ive mever understood bolts etc, i get it when its in mm and inches, but what does it mean by m8, i know thats 8mm cos it says, but why m8?? i found this bar, going to make my own up http://cgi.ebay.co.uk/STAINLESS-STEEL-M8-8MM-THREADED-BAR-ROD-STUDDING-100mm-/270651820109?pt=UK_DIY_Material_Nails_Fixing_MJ&hash=item3f041b084d
| December 2nd, 2010, 9:37 pm |
dave 411
Joined: August 19th, 2010, 10:44 pm Posts: 1815 Location: Cardiff
so whats the fuel pipe question?
_________________ [img]http://i1207.photobucket.com/albums/bb480/alastairsmith999/dave411-5.png[/im g]Horizontally Opposed
| December 2nd, 2010, 9:39 pm |
Users browsing this forum: No registered users and 54 guests |
