View unanswered posts | View active topics It is currently May 1st, 2026, 4:16 pm
Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 right.. no debates, no arguments just honest opinons please!
Post Re: right.. no debates, no arguments just honest opinons ple
Jonathan wrote:
The BMC A-Series engine was originally fitted with points, but Austin-Rover replaced that with electronic ignition in the mid 80s.
My 1989, 1990, 1992 Minis all had points as standard. It was only the Posher stuff that had electronic ignition.
October 26th, 2010, 8:53 pm
Gosh :shock: Well, my Mini was a 1.3 1993 model.
October 26th, 2010, 9:06 pm
Did I mention POINTS? ;)
October 26th, 2010, 9:11 pm
Twelve sets of points & condenser for one 123!!
Definitely must be worth thinking about..............£££££££sssss less.
Take some time & learn how to set up points correctly, you'll not regret it.
October 26th, 2010, 10:28 pm
great advice !
October 26th, 2010, 10:30 pm
Hear hear, well said that man.
setting the points is a 2 minute job, its so easy, once youve done it once itll take you 2 minutes, obviously the timing will then need doing, but that again doesnt take long at all! the only painful bit to doing the points is getting the fan off, ive mastered this, i have the nack ;)
my trick is to et my 14mm socket on the end of my 3/8ths extender bar, and position it in 4 different positions, for example north east south and west, and give it a good tap with the hammer in each position, and i keep hitting going round until eventually ping, of it comes, works every time!
October 26th, 2010, 10:35 pm
What if you can't fit them your self? Labor? How many sets if paying someone to do it?
October 26th, 2010, 10:36 pm
i would imagine it still works out cheaper, however, how long does a 123 system last? and how long is the life exspectancy of points?
October 26th, 2010, 10:38 pm
Learn!
October 26th, 2010, 10:54 pm
