View unanswered posts | View active topics It is currently June 30th, 2025, 4:51 am
 Fuel Additives ????
Post Fuel Additives ????
what's the general consensus on these?
specifically 'metal on metal protection' - replace the lead type stuff???
cheers
W
July 29th, 2010, 4:48 pm
Post Re: Fuel Additives ????
cheers
W
Serious waste of good money is my opinion. If you look after your engine [regular oil changes] and keep the air ways clean, 2CV engines are fine.
July 29th, 2010, 6:01 pm
2nd that
fuel additives, fuel catalists, magnets etc a waste of time and cash
July 29th, 2010, 6:10 pm
Have not had any problems with unleaded on my car, and it's now on 193,000miles. Save your money for something else.
July 29th, 2010, 6:39 pm
I thought later A series were always fine with unleaded anyway as unleaded was common before the end of production? I certainly haven't worried about it.
July 29th, 2010, 6:42 pm
A-series heads are ally. Ally heads need valve seat inserts.
Cast iron heads often didn't have valve seat inserts, because the lead provided the protection. Remove the lead, and you're left with a relatively soft seat, which suffers from recession.
The official line from Citroen was that all engines from number <whatever> were OK - but AIUI the suspicion's always been that that was just the number of the engine they tested, since the part number for the head didn't change.
July 29th, 2010, 6:55 pm
Hi
Reason for asking was, in this warmer weather, my engine won’t fire up straight away when the engine is hot – takes a couple of goes. A friend suggested that it might be because the exhaust valves aren’t quite doing what they’re supposed to, so a teaspoon of Castrol Valvemaster into a full tank would “make all the difference”……not sure it’s made any, to be honest…..but – will it harm the valves??? Seats????
And is the hot starting problem just one of those twin pot nuances???
Thanks all
Will
July 30th, 2010, 11:38 am
Usually, everyone says "coil" which is certainly what happened to me recently. I've also been told it depends how you give it throttle on startup - foot to the floor, then turn the key and back off the throttle when it kicks in is a tip I've been told.
July 30th, 2010, 11:41 am
You know what your friend is full of, don't you?
July 30th, 2010, 11:42 am
Yes don't listen to nonsens but people ''in the know''
July 30th, 2010, 11:43 am
