View unanswered posts | View active topics It is currently November 20th, 2025, 7:05 am
 auxialliray fuel tank
Post Re: auxialliray fuel tank
5cm deep as the boot foor starts at the bottom of the boot.
Back end of the 4x4 has been chopped off to give a better departure angle.
July 2nd, 2010, 8:26 pm
oh didnt realise you where a 4x4 2cv
always wanted to have a looksie at one to see how it all works they look cool
should of geussed you 2cv was 4x4 by your name but you never know
July 2nd, 2010, 8:27 pm
It will be at the National so come along and have a look.
July 2nd, 2010, 8:39 pm
if im there i shall :)
July 2nd, 2010, 8:41 pm
Kept that one under your hat didnt you lenny? very smart indeed.
July 2nd, 2010, 8:46 pm
Only fitted it a few weeks back. The trial run was the London to Brighton weekend. We made it from the most northern bit of Lincolnshire to Brighton without refuelling. Very pleased with it.
If I did it again I'd put some sort of float in it to switch the pump off automatically when the tank is empty. Having said that, the pump makes such a racket when it runs dry that you can't fail to remember to turn it off.
July 2nd, 2010, 9:52 pm
That is a top bit o' kit, Lenny! was the tank fabrication expensive?
July 2nd, 2010, 9:53 pm
He charged me sixty quid which I thought was quite reasonable. It's made out of 1mm steel which I then had powdercoated. I also used some tank sealer just to be sure.
Ideally it'd be made out of alloy to make it a bit lighter but it's not too heavy as it is.
July 2nd, 2010, 10:32 pm
very reasonable! he should start knockin' 'em out!
July 2nd, 2010, 10:36 pm
Certainly on my list of things for the future. Amazing idea
did you supply the metal also?
July 2nd, 2010, 11:45 pm
