J-dub
 clunking? when turning
another strange one from me, but when i stear like turn (only noticed it to the right but never seem to turn left and have this, but if im doing 5mph ish and i turn right (similar to do a 3 point turn) ill be on a good amount of lock, and i get clunk, clunk, as i slow down, my dad said 2cv joints but i just wanted to ask your opinions, is it a disaster waiting to happen?! thanks
| June 5th, 2010, 11:35 pm |
terpineol
 Re: clunking? when turning
Mine does it too, I've never thought much of it.
| June 6th, 2010, 12:25 am |
Joe
i get it every now and then when i come off a roundabout. its hard to explain! i thought it might be the inner wing rubbing on the tyre because i bent it a bit when i took it off and put it back on.
| June 6th, 2010, 12:32 am |
james2cv
Joined: April 18th, 2009, 8:01 pm Posts: 947 Location: Paris/Manc
Probably driveshaft joints but maybe worn kingpins rubbing on the rear of a knackered wheel? However if it was that bad I'd guess it would be all the time and not just round corners? Get it to a car park and drive round in circles both ways and see if you can narrow it down. You might aswell check the obvious like inner wing on chassis/suspension arms aswell... My inner wing is rubbing somewhere at the moment and I can't track it down
| June 6th, 2010, 12:47 am |
J-dub
ok, well ive never thought anything of it i just wanted to check  ive always just ignored it as i thought it was normal
| June 6th, 2010, 8:43 am |
ben
It'll be your inner part of the wheel where the wheel's seam is rusted and lifted just enough to clout the kingpin at the bottom when you go round corners due to a tiny amount of movement as the weight goes onto that wheel. Quick fix = bash the raised bits of seam back down and de-rust ,proper fix= new wheel .
| June 6th, 2010, 9:21 pm |
J-dub
proper fix i shall go for, as soon as i have the money im going for new wheels as i know my wheelse have life in them, but i dont like the look of the rusty seems, and rather be safe than sorry !!!!
| June 6th, 2010, 11:25 pm |
ben
Be a good idea to whip the wheel off and tap the seams down with a hammer where they are raised with rust then try it just be to double sure.
| June 7th, 2010, 8:54 am |
samfieldhouse
ben wrote: It'll be your inner part of the wheel where the wheel's seam is rusted and lifted just enough to clout the kingpin at the bottom when you go round corners due to a tiny amount of movement as the weight goes onto that wheel. Quick fix = bash the raised bits of seam back down and de-rust ,proper fix= new wheel . Yep. New wheels are the way to go
| June 7th, 2010, 5:58 pm |
J-dub
i better start adding to my 2cv money box (yes i have a 2cv money box! had it all my life!)
| June 7th, 2010, 11:57 pm |
Users browsing this forum: No registered users and 107 guests |
