View unanswered posts | View active topics It is currently November 20th, 2025, 4:45 am
Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
 clunking? when turning
Post clunking? when turning
another strange one from me, but when i stear like turn (only noticed it to the right but never seem to turn left and have this, but if im doing 5mph ish and i turn right (similar to do a 3 point turn) ill be on a good amount of lock, and i get clunk, clunk, as i slow down, my dad said 2cv joints but i just wanted to ask your opinions, is it a disaster waiting to happen?!
June 5th, 2010, 11:35 pm
Post Re: clunking? when turning
Mine does it too, I've never thought much of it.
June 6th, 2010, 12:25 am
i get it every now and then when i come off a roundabout. its hard to explain! i thought it might be the inner wing rubbing on the tyre because i bent it a bit when i took it off and put it back on.
June 6th, 2010, 12:32 am
Probably driveshaft joints but maybe worn kingpins rubbing on the rear of a knackered wheel? However if it was that bad I'd guess it would be all the time and not just round corners? Get it to a car park and drive round in circles both ways and see if you can narrow it down. You might aswell check the obvious like inner wing on chassis/suspension arms aswell... My inner wing is rubbing somewhere at the moment and I can't track it down :evil:
June 6th, 2010, 12:47 am
ok, well ive never thought anything of it i just wanted to check :D
ive always just ignored it as i thought it was normal
June 6th, 2010, 8:43 am
It'll be your inner part of the wheel where the wheel's seam is rusted and lifted just enough to clout the kingpin at the bottom when you go round corners due to a tiny amount of movement as the weight goes onto that wheel. Quick fix = bash the raised bits of seam back down and de-rust ,proper fix= new wheel .
June 6th, 2010, 9:21 pm
proper fix i shall go for, as soon as i have the money im going for new wheels as i know my wheelse have life in them, but i dont like the look of the rusty seems, and rather be safe than sorry !!!!
June 6th, 2010, 11:25 pm
Be a good idea to whip the wheel off and tap the seams down with a hammer where they are raised with rust then try it just be to double sure.
June 7th, 2010, 8:54 am
Yep. New wheels are the way to go :?
June 7th, 2010, 5:58 pm
i better start adding to my 2cv money box (yes i have a 2cv money box! had it all my life!)
June 7th, 2010, 11:57 pm
Users browsing this forum: Google [Bot] and 16 guests
