suspension hEight adjustment
J-dub
hello,
just wondering if anyone could shed a bit of light on how to adjust the suspension adjust the tie rods? if so how?
un even suspension! and want the car to go a little higher
thanks
| May 20th, 2010, 11:47 pm |
Joolz
 Re: suspension hight adjustment
Jameswallace wrote: and want the car to go a little higher We've no time for any of that nonsense here. Did you go and read the 'All about: 2CV suspension' thread like you were told to? It's there on the first page, (third paragraph)  .
| May 21st, 2010, 12:16 am |
J-dub
i did and i printed it out but and saw it, but do i have to take the tie rods of anything is what i was after....
| May 21st, 2010, 8:26 am |
toomany2cvs
Jameswallace wrote: i did and i printed it out but and saw it, but do i have to take the tie rods of anything is what i was after.... No, just jack the car up, and turn 'em.
| May 21st, 2010, 9:28 am |
Paul Narramore
Joined: November 16th, 2009, 10:14 am Posts: 211 Location: Aylesford, Kent
James It's so easy it barely warrants describing it. Once you've jacked on side up you'll see the tie rods front and back. It will become obvious when you use a 10mm spanner on the flats of the tie rods. If the rods won't turn, the threads will have seized and I've used Mole grips in the past. However it's best to remove the tie rod ends completely, clean up then grease the threads, replace them then try again.
| May 21st, 2010, 10:47 am |
louise2cv
9mm?
| May 21st, 2010, 11:55 am |
Rhythm Thief
Joined: March 10th, 2010, 12:37 am Posts: 1927 Location: Alone in my polytunnel with my pitiful competition onions
9mm. Or mole grips, if your car is anything like mine was. You'll probably need to cut a 9mm spanner down so it fits between the tie rod and the chassis.
_________________ The best things in life aren't things.
| May 21st, 2010, 12:00 pm |
toomany2cvs
| May 21st, 2010, 12:09 pm |
Rhythm Thief
Oh, and it's "h eight", by the way.
| May 21st, 2010, 12:55 pm |
terpineol
 Re: suspension hEight adjustment
Jack car up, and if your tie rods have the flat bit left try a 9mm spanner, if not its hello Mr Molegrips.
Screw them into the ends to go up, out to go down.
| May 21st, 2010, 2:09 pm |
Users browsing this forum: No registered users and 78 guests |
