View unanswered posts | View active topics It is currently November 20th, 2025, 12:13 am
Reply to topic  [ 50 posts ]  Go to page 1, 2, 3, 4, 5  Next
 suspension hEight adjustment
Post suspension hEight adjustment
hello,
just wondering if anyone could shed a bit of light on how to adjust the suspension adjust the tie rods? if so how?
un even suspension! and want the car to go a little higher
thanks
May 20th, 2010, 11:47 pm
Post Re: suspension hight adjustment
We've no time for any of that nonsense here. :P
Did you go and read the 'All about: 2CV suspension' thread like you were told to? It's there on the first page, (third paragraph) :roll: .
May 21st, 2010, 12:16 am
i did and i printed it out but and saw it, but do i have to take the tie rods of anything is what i was after....
May 21st, 2010, 8:26 am
No, just jack the car up, and turn 'em.
May 21st, 2010, 9:28 am
James
It's so easy it barely warrants describing it. Once you've jacked on side up you'll see the tie rods front and back. It will become obvious when you use a 10mm spanner on the flats of the tie rods. If the rods won't turn, the threads will have seized and I've used Mole grips in the past. However it's best to remove the tie rod ends completely, clean up then grease the threads, replace them then try again.
May 21st, 2010, 10:47 am
9mm?
May 21st, 2010, 11:55 am
9mm. Or mole grips, if your car is anything like mine was. :D
You'll probably need to cut a 9mm spanner down so it fits between the tie rod and the chassis.
May 21st, 2010, 12:00 pm
Or, unless you're a total masochist, one of these...
http://www.ecas2cvparts.co.uk/suspensio ... p-154.html
May 21st, 2010, 12:09 pm
Oh, and it's "height", by the way. ;)
May 21st, 2010, 12:55 pm
Post Re: suspension hEight adjustment
Jack car up, and if your tie rods have the flat bit left try a 9mm spanner, if not its hello Mr Molegrips.
Screw them into the ends to go up, out to go down.
May 21st, 2010, 2:09 pm
