View unanswered posts | View active topics It is currently September 24th, 2025, 5:26 pm
Reply to topic  [ 38 posts ]  Go to page 1, 2, 3, 4  Next
 Oz duck wannabe
Post Oz duck wannabe
This 2CV is heading down under to continue her life but the rust needs removing before. It will be a Personal Import so the 2CV doesn't need to comply with ADR (Australian Design Rules) except be roadworhty.
This French rivert repair job will be rejected in Oz. What do I find underneath?
Rust never sleep.
Both floors and pedal floor gone. Well seen it all before, no surprise here.
More later, back to work
January 10th, 2010, 12:28 pm
Post Re: Oz duck wannabe
The real surprise is that it's not taken the chassis out, too...
WHY DO THEY DO IT?
January 10th, 2010, 1:09 pm
Chassis is galvanized. I guess they just changed the chassis and ignored the rust by plating it. I showed it to one of our french customers and he said, ''so what'' normal to him :o
January 10th, 2010, 1:14 pm
Ah. The tin floor already killed that...
January 10th, 2010, 1:26 pm
Yep
Time for coffee INSIDE, its bloody cold, no heating, aarrghhhh
Stage one
Outer pedal floor welded in and coated with premier.
January 10th, 2010, 4:21 pm
One more coffee break, waiting for the premier to dry
Stage 2
Inner pedal floor done, except the egdes where sills will join later.
January 10th, 2010, 6:03 pm
So you can replace just the bottom of the inner front bulkhead then?
January 10th, 2010, 7:38 pm
Yes, no need to replace the complete lower pedal floor. Must times it is only these panels which are rotten.
Goodbye right floor and sills. New tomorrow.
January 10th, 2010, 8:45 pm
Cheers Viking that's good to know. Bottom of my inner front bulkhead's going where it joins the floors (they're going too).
January 10th, 2010, 9:00 pm
Today's effort. RHS floor and sill stitched it, still need to fix front and rear door posts. Rotten as usual. Still struggeling with 0 temp. but thats life.
January 12th, 2010, 9:52 pm
Users browsing this forum: No registered users and 439 guests
