View unanswered posts | View active topics It is currently August 13th, 2025, 7:41 pm
 For your delight and amusement......
Post For your delight and amusement......
Broke down today cruising along the M6 on the way to work. Car had spat out its spark plug. The thread in the head has gone, so taking it to the garage tonight, heli coiled tomorrow, tinternash on the Sat. Boom.
August 27th, 2009, 5:06 pm
Post Re: For your delight and amusement......
Bad times!!
Glad you're still in the game for the weekend though. ;)
August 27th, 2009, 7:48 pm
Join the club! mine did that about a month ago. but i got a threaded insert put inside as the hole in the cylinder was a bit too ovalled! its a quickish job though. it makes a horrible noise though dosnt it! (and these cars are no fun on one cylinder)
goodluck with the fix!
Joe.
August 27th, 2009, 8:24 pm
quick question... Why do i see alot of 2cv pictures with bungeeeeees across the bonnet? What is the reason?
getting there slowly.
August 27th, 2009, 8:26 pm
Me 2.. First time in may. Lucky for me the thread wasn't damaged too bad, so I could fix it on the side of the road.
One month later, june it flew out again... This time no thread left, so continued my journey together with the ANWB:
It's can be that the bonnet-lock is a but rusty (the bit on the bonnet) and it can come loose when you drive.
Whats left is a bend/buggerd bonnet, maybe a broken front window, damaged roof and panic all the way because it's impossible to see anything in front of you.
I'm using from those rubber hooks (see picture).
Last edited by Tom Duckpower on August 27th, 2009, 8:39 pm, edited 1 time in total.
August 27th, 2009, 8:30 pm
it's to stop your bonnet flying up & smacking the top of the 'screen surround, not that it happens that often & you should be ok if your bonnet catch is adjusted properly. It just gives you piece of mind really.
August 27th, 2009, 8:36 pm
or on a 4x4 if it has no bonnet catch
August 27th, 2009, 8:56 pm
Or just for the look.
August 27th, 2009, 9:15 pm
Yep, it was very noisy! It's weird how when things go wrong with a 2CV, I generally remain kind of calm. As long as it's one thing, not a chain of events. Like a tyre exploding, and a lorry reversing onto me. That would be terrible.
Put a slightly longer spark plug in with a washer on, this managed to grip onto the remaining thread, enough to get me the 15 miles or so t' garage in Stoke. So the mothership didn't have to tow me, because she was freaking out about it. Just got to pick it up early Sat morning then I'm coming over to the tinternash. Put my wine in the cooler! Wish I was there now like....stupid work.
Bungee cord is possibly not that essential for me, but I have a bit of paranoia seeing my bonnet jump around, so I prefer to keep it on. I've gone for the none matching yellow option. Classy.
See you all at the weekend hopefully. :P
August 27th, 2009, 10:15 pm
As I remember it a GSA plug is threaded longer than 2CV so it is possible to use one of these to get you home. Just be carefull fitting them tho as if you screw them in too far they will hit the head.
I saw this work at the 50th Anniversary Meeting years ago when someone took a spare plug from my Acdyane 1300!! and it go the 2CV back from Paris to the UK.
August 27th, 2009, 11:49 pm
