View unanswered posts | View active topics It is currently June 19th, 2026, 12:26 am
 Rear Diff with Reduction Gears.
Post Rear Diff with Reduction Gears.
Progressing with building a light-weight Rear Diff with Reduction Gear and Selector.
The prop shaft will run through the cabin.
May 5th, 2025, 2:59 pm
Post Re: Rear Diff with Reduction Gears.
May 8th, 2025, 9:14 am
nice job.
May 8th, 2025, 10:47 pm
Awesome ... :D
May 13th, 2025, 7:47 pm
I am always amazed at how people can make or modify technical things .
My son is the same way, often making a sketch of how it should be, the details are then in his head, or working out during construction .
May 13th, 2025, 8:22 pm
Now its warmer :)
Fabricated all the parts, now to final assembly?
February 23rd, 2026, 12:15 pm
Almost done, new shafts made, need heat traetment.
Front Box.
Rear Diff/Box
ps
Fakebook is easier to. use, just shiiiiiiiiiiiiiit.
June 15th, 2026, 6:11 pm
How about the weight? On my rear diff, with reduction gears, with disc brakes the scale said 27 kg...
Didn't check the weight without brakes, I should check but maybe next time it is out..?
June 16th, 2026, 9:14 am
With brakes 28Kg , but cut down bellhousing, cut down input shaft and no syncro parts:)
June 16th, 2026, 9:40 am
My bellhouse is also cut, as much as possible. Not cut any other shafts, but input shaft a little bit. Some photos can find on my topic, if photos is possible to see. Thanks to photo bucket, photos are there but not sure if they are visible nowadays... I have them somewhere, need to upload them to another place to hotline them. Some day, some year..?
June 16th, 2026, 12:15 pm
