View unanswered posts | View active topics It is currently February 3rd, 2026, 10:11 am
Reply to topic  [ 984 posts ]  Go to page Previous  1 ... 95, 96, 97, 98, 99  Next
 AZL 1957
Post Re: AZL 1957
Very sweet.
August 27th, 2025, 7:48 pm
Post Re: AZL 1957
Wanted to get the 57 from the garage but starter turned slow. So checked the sparkplugs. Cleaned and tested there was a very weak spark... So took the battery home to hook it at the large vintage Philips charger 6 amps. It did charge all evening and held a 6,7 volts which is normal... But this morning there was only 4 volts left, so one of the cells must be dead. So game over. I did order a new battery 140 amps in stead of the 66 amps i had now. That gives some more starting power...
October 31st, 2025, 5:53 pm
Post Re: AZL 1957
I had some cranking/starting issues with the Shed. The battery is charged and in a cupboard at the moment waiting for some better weather. :D
October 31st, 2025, 6:21 pm
Post Re: AZL 1957
And does the cupboard start now?.... ;-)
October 31st, 2025, 7:07 pm
Post Re: AZL 1957
Got a new battery a bit more amperes than the old one. The car started within half a turn of the engine now. Only brakes are a bit weak. Will have to check this... Or i am used to the disc brakes... :mrgreen:
November 5th, 2025, 6:22 pm
Post Re: AZL 1957
No, your new battery is too heavy, breakes are not made for such extra heavy weight . :lol:
November 5th, 2025, 7:39 pm
Post Re: AZL 1957
I will have to find the key and try it ... :lol:
November 5th, 2025, 7:48 pm
Post Re: AZL 1957
Well took a brake drum off at one side. The brake shoes were a little greasy but only one of the wheelcylindre pistons did move. So complete demontage and cleaning....pfpf. Lucky it's still nice and dry outside.
November 6th, 2025, 5:38 pm
Post Re: AZL 1957
Did clean brake shoes and drums. Wheels cylinders did move... so tomorrow adjust the brakes and bleed the brakes.
November 7th, 2025, 4:36 pm
Post Re: AZL 1957
So first adjusting the brakes, the rear brakes could be adjusted more than a half turn...
in front shoes were almost in contact. Bleeding didn't bring out any air. Little test, brakes gripped fine now...
November 8th, 2025, 7:04 pm
Users browsing this forum: No registered users and 482 guests
