View unanswered posts | View active topics It is currently May 7th, 2026, 1:04 pm
Reply to topic  [ 993 posts ]  Go to page Previous  1 ... 88, 89, 90, 91, 92, 93, 94 ... 100  Next
 AZL 1957
Post Re: AZL 1957
You're so lucky. Gorgeous cars you have.
November 17th, 2024, 11:56 am
Post Re: AZL 1957
I know, i got them at a time when prices were reasonable. Today it's become stupid...
November 17th, 2024, 1:59 pm
Post Re: AZL 1957
They're both incredible. I know I always say it but I'm a bit in love with the yellow one.
November 18th, 2024, 11:50 pm
Post Re: AZL 1957
it works again...Thanks Roger.
December 15th, 2024, 12:50 pm
Post Re: AZL 1957
The yellow 57 was a bid reluctant on starting. So took the plugs out and cleaned them. Now after 1/4 rpm it springs into life.
December 16th, 2024, 5:33 pm
Post Re: AZL 1957
Well that was only once....Yesterday it didn't want to start at all. This morning i did put a sparkplug in the cable to see if there was a spark. When i turned the engine by hand there was a spark. But when i started it with the starter motor the spark was very weak and it missed some. So i took the ignition out and to my surprise both contact points had a coat of oxydation on it... So all out to clean. And with the fan out i did also find my non detectable oil leak i think. Both bolts that hold the oil cooler were wet with oil....So i think there is something wrong there. Let's see if can repair that too.
December 26th, 2024, 5:40 pm
Post Re: AZL 1957
I did put in the points and clipped the wires that secure the banjo bolts of the oil cooler. I put the socketspanner on to undo them as i just tried to see if they could be thightend.....Of course stupid me, i just forgot to torque them up.....
So gave that a try end put new wires in....
But the car didn't start. The battery was to empty of all that trying en the cold added some more decharge. So i put it on charge....we will see tomorrow.
December 27th, 2024, 4:29 pm
Post Re: AZL 1957
This little car seems so reliable normally.
Last edited by Ianredspecial on January 4th, 2025, 7:29 pm, edited 1 time in total.
December 27th, 2024, 4:46 pm
Post Re: AZL 1957
Yes it start at -7 degrees no problem normally... Will see if it want to start tomorrow.
December 28th, 2024, 1:03 am
Post Re: AZL 1957
Recharged battery in the car divers tries...no luck. Changed coil, nothing. I did put the choke back to zero and a little splutter...no start. Took the idle jet out, cleaned. An other try and 1/4 turn and it sprung to life... super. Cleaned out the heating tunnels. So hope the oily smell is gone now too...
December 28th, 2024, 12:59 pm
Users browsing this forum: No registered users and 152 guests
