View unanswered posts | View active topics It is currently June 19th, 2026, 4:42 am
Reply to topic  [ 129 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13  Next
The saga so far.....
Standard parts, Modified Parts and new parts.
The "new" parts not yet, necceassarly in the correct order :)
Some of the bits to do ... Oil Seal for selector rod, and (gear) lever for selector rod.
Estimated additional total weight about 14Kg :(
June 26th, 2024, 1:33 pm
Selector rod parts. Seal and interlock.
July 2nd, 2024, 6:42 pm
Selector Lever...
Ouput Engaged.
Output Disconnected.
Access to Oil filler & level a bit comprimised :(
July 6th, 2024, 11:11 am
Bend that lever. A tight bend just over the uniball, and another over filler plug to the direction desired. Problem solved..?
July 6th, 2024, 1:57 pm
Feasable, also have a spare one of these
July 6th, 2024, 2:45 pm
Fits together but will it fit in the car? :)
July 8th, 2024, 12:10 pm
Fingers crossed !
July 8th, 2024, 2:14 pm
Re-made the Bearing retainer and oil seal holder, was somehow out of alignment :( :(
July 15th, 2024, 5:19 pm
After some very careful measureing :) , I can fit a triplex chain and sprockets, whick only adds 5mm to the caseing depth. Had to redo the selector interlock....etc
July 16th, 2024, 8:41 pm
Trial fit with a a dummy chassis rail, its a very tight fit!!
However if I reduce the height by "20mm" not so tight.
Means I have to make a new back plate:(
July 30th, 2024, 10:51 am
