Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1199 Location: Magyarország
 Re: Transfer box.. A new version...
well you learn as you progress.
| June 7th, 2024, 6:39 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2254 Location: Near Monmouth
Duplex chain... Mock up to see how to make the rear cover (many parts!!) The thin plate bit in the middle is for of the clearance axle/steering tube. Attachment:
| June 8th, 2024, 11:52 am |
subarupete
Back cover coming together, mild panic and curse it didnt fit on first try, it was the wrong way up:) Attachment:
| June 11th, 2024, 4:05 pm |
subarupete
Getting there --------- top shaft/bearing end plate Attachment:
| June 13th, 2024, 12:42 pm |
subarupete
Bit of a disaster... Had planned to use "o" ring material a seal. Two broken 3.5mm end mills and the result is a mess.  Will now use old fashioned gaskets.  Attachment:
| June 15th, 2024, 8:58 am |
subarupete
Will it fit???? Attachment:
| June 15th, 2024, 11:55 am |
subarupete
Couple of photos............ Attachment:
| June 15th, 2024, 5:14 pm |
subarupete
Last major part of the housing added. Attachment:
Some views..... its quite large, possibly over engineered, unlike Colin Chapman, said only add "lightness"  Attachment:
| June 18th, 2024, 4:45 pm |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2287 Location: South-Limburg
Well made...so the driveshaft goes inside the chassis?
| June 18th, 2024, 10:47 pm |
subarupete
Yes, like a 4x4 Mehari
| June 19th, 2024, 7:42 am |
Users browsing this forum: No registered users and 35 guests |
