View unanswered posts | View active topics It is currently April 28th, 2026, 10:46 am
Reply to topic  [ 129 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12, 13  Next
well you learn as you progress.
June 7th, 2024, 6:39 pm
Duplex chain...
Mock up to see how to make the rear cover (many parts!!)
The thin plate bit in the middle is for of the clearance axle/steering tube.
June 8th, 2024, 11:52 am
Back cover coming together, mild panic and curse it didnt fit on first try, it was the wrong way up:)
June 11th, 2024, 4:05 pm
Getting there --------- top shaft/bearing end plate
June 13th, 2024, 12:42 pm
Bit of a disaster...
Had planned to use "o" ring material a seal. Two broken 3.5mm end mills and the result is a mess. :(
Will now use old fashioned gaskets. :)
June 15th, 2024, 8:58 am
Will it fit???? :shock:
June 15th, 2024, 11:55 am
Couple of photos............
June 15th, 2024, 5:14 pm
Last major part of the housing added.
Some views..... its quite large, possibly over engineered, unlike Colin Chapman, said only add "lightness" :)
June 18th, 2024, 4:45 pm
Well made...so the driveshaft goes inside the chassis?
June 18th, 2024, 10:47 pm
Yes, like a 4x4 Mehari ;)
June 19th, 2024, 7:42 am
Users browsing this forum: Bing [Bot] and 18 guests
