AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2278 Location: South-Limburg
 Re: My Beduino
Also on an early 2cv6 or ami. Just different jets. I installed one on my 2cv6, it pulls better uphill.
| February 11th, 2024, 11:44 am |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1196 Location: Magyarország
 Re: My Beduino
Yes indeed , I forgot to mention these .
| February 11th, 2024, 1:08 pm |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1661 Location: Exeter, Devon
 Re: My Beduino
I did wonder if it would make a nice throttle body. Though I suppose a twin choke would work just as well.
| February 11th, 2024, 8:54 pm |
Roger V
 Re: My Beduino
A little progress
| February 16th, 2024, 9:29 am |
Roger V
 Re: My Beduino
Some more progress  The spacer needs the rough edges cleaned back, but this is what it looks like in place. The stud holes have been drilled out since this image  I will look into getting a pair of tyres fitted this week. 145/65 R15
| February 18th, 2024, 11:08 pm |
AZL57
 Re: My Beduino
Are this visa wheels?
| February 19th, 2024, 7:26 pm |
Roger V
 Re: My Beduino
GS/A At least, I understand them to be GS/A
| February 19th, 2024, 7:58 pm |
AZL57
 Re: My Beduino
Oh yes that could be it.
| February 19th, 2024, 8:53 pm |
jasu
Joined: August 8th, 2012, 11:00 am Posts: 508 Location: Korpilahti, Finland
 Re: My Beduino
Bolt patterns:
Visa 3x115 GS/A 3x160 2CV 3x160
Those are definetly GSA wheels...
One solution to solve the problem with steering and GS wheels. Drill another holes 8mm further, on steering arm, or make new M7 threads to *part where is bearing and the steering arm bolted in...
But, I think the spacer is better, then the wheel will be at right spot. With that steering arm re-aligning, wheel bearings don't last as long as with original. Some friends made that modification, and they all find that problem with bearings...
One other solution is still to be tested, after I can have some spacers made. Put a 6mm spacer between wheel flange and bearing, so the flange comes 6mm out of hub. I think there is enough at drive shaft end, to make that. With photo that should be much easier to explain, maybe when that is tested..?
*Really, forgot that part name. Hub? No. Something else?)
| February 20th, 2024, 12:21 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2251 Location: Near Monmouth
 Re: My Beduino
Citroen 2CV Front Hub (Wheel) Flange
| February 20th, 2024, 3:06 pm |
Users browsing this forum: No registered users and 686 guests |
