View unanswered posts | View active topics It is currently May 7th, 2026, 6:20 pm
Reply to topic  [ 348 posts ]  Go to page Previous  1 ... 29, 30, 31, 32, 33, 34, 35  Next
 My Beduino
Post Re: My Beduino
Thanks Pete. I've started reading the build.
@Joolz does suggest he resolved the issue with a 6mm spacer, and mentions the shorter thread. But doesn't really say, if it was satifactory. :)
Though, I am only on page 19 of 54. :D
February 5th, 2024, 12:06 pm
Post Re: My Beduino
I did have some “arms” laser cut from 20mm steel, reduced with lots of grinding with an long ht bolt and rod end.
Will dig it out and do a photo also got a quote for longer wheel studs, but at £8 each didn’t go that route.
February 6th, 2024, 1:52 pm
Post Re: My Beduino
Pete, that would be interesting to see :)
February 7th, 2024, 2:33 pm
Post Re: My Beduino
Unfinished, the taper foot from a junk arm is welded in a rectanglar hole.
Welding not approved fot steering parts, but who will see it:(
February 7th, 2024, 3:40 pm
Post Re: My Beduino
I've ordered some 6mm plate for the spacers. I picked up a pre used drill press the other day, so will be careful cutting out the middles and edges. Then I will have some scrap alloy to practice tig on. :D
February 8th, 2024, 8:14 pm
Post Re: My Beduino
Iv'e designed and 3D printed a template for the spacer.
I will probably print templates to fit in the wheel stud holes to aid centering the pilot drill. Then I think I will bolt the template to the Alloy, and work my way around with the drill. Then finally file it to the finished shape.
Then ... I need to buy some tyres ....
February 9th, 2024, 11:08 pm
Post Re: My Beduino
Thought my birthday had come early! :D
A chap contacted the local group to say he had some 2CV spares to clear out from the garage. Been there there a good while now, and free to whoever wants it, or it goes to recyling.
So I trundle up to Okehampton from Exeter. About 30 miles. And pick up an orange box!
2 alternators, 2 carbs (one is single venturi), 2 fuel pumps. 2 fan belts. 3 hub caps! Brake shoes, brake cylinder. What looks to be a brake centering tool made from a cut up drum. A cut off gearbox primary shaft to use as a clutch centering tool. And a multitude of other bits and bobs rattling around in the bottom of the box. :D
It's not a box you would want to carry to far!
I will add to the list, if I find anything interesting. :D
February 10th, 2024, 9:03 pm
Post Re: My Beduino
Well done to save the parts.
February 10th, 2024, 9:32 pm
Post Re: My Beduino
The single venturi carb, what would that fit?
February 10th, 2024, 11:17 pm
Post Re: My Beduino
2CV 4, 425/435 cc
February 11th, 2024, 9:18 am
Users browsing this forum: No registered users and 267 guests
