subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2257 Location: Near Monmouth
 Re: EPB Refurb
Inside Dash and propshaft tunnel etc Attachment:
Prop tunnel is fabricated from Alu, saved about 8kg from the orginal heavy steel version, coved with thin carpet to reduce sound/resonce. Extra panel for USB, Diesel Heater Control, Map Light, Reverse lamp, Alu Lever is the rear brake line lock valve. Attachment:
Speedo from a Quad with small speed sensor (no need for a 2.5 meter speedo cable from the rear diff) Citroen switches/ and relays and lamps with LEDs fitted.
| October 3rd, 2022, 12:58 pm |
subarupete
 Re: EPB Refurb
Still got a long list but jobs are smaller.. Attachment:
| October 18th, 2022, 5:26 pm |
subarupete
 Re: EPB Refurb
Current state Attachment:
| November 8th, 2022, 11:03 am |
Roger V
 Re: EPB Refurb
Shiney
| November 8th, 2022, 1:57 pm |
subarupete
 Re: EPB Refurb
Cylinder Heads. Exhaust Vales ok. Inlets to much wear, so new items. Using my £10 dial guage (Car Boot) Attachment:
Tubes fitted with rawl plug M8 (have made a more robust tool.) Also M8 exhaust studs the old M7 studs very rusty. Attachment:
Head on left after Vapour Blast  Attachment:
My bargin crank from ebay in 2014 is a very large door stop
| December 3rd, 2022, 3:09 pm |
Roger V
 Re: EPB Refurb
 Who did vapour blast?
| December 3rd, 2022, 11:10 pm |
subarupete
 Re: EPB Refurb
MTP Services Unit 1, Ladygrove Business Park Mitcheldean Gloucestershire GL17 0DS Cylinder heads £25 !
| December 4th, 2022, 10:32 am |
Roger V
 Re: EPB Refurb
I don't like spending money on things like that  How much better will it make it run?
| December 4th, 2022, 5:54 pm |
subarupete
 Re: EPB Refurb
Parts need to be cleaned before they are machined also allows any cracks or defects to be seen.
| December 4th, 2022, 7:48 pm |
Roger V
 Re: EPB Refurb
valid point  I just shove it in
| December 4th, 2022, 8:22 pm |
