View unanswered posts | View active topics It is currently June 19th, 2026, 2:33 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 97, 98, 99, 100, 101, 102, 103 ... 105  Next
 Make Your Own ....2CV.... 4x4
Post Re: �Make Your Own ....2CV.... 4x4
@Edce,
Air suspension has been done by a few,
See here
https://m.youtube.com/watch?v=tFGh_A-JW3g
https://forum.retro-rides.org/thread/65449/airride-2cv
Peter
June 28th, 2020, 10:23 am
Thnks for the references SubaruPete. I have seen these video's before. Lpgo is again in the picture here. Don't know (yet) if he finished the construction both at the back and the front suspension. I will visit him in a while and can talk about his solution.The other video doesn't show anything of the applied construction, sadly enough.
June 28th, 2020, 10:58 am
The “Crazy Belgian “ has hollow centre airbags in place of the springs and longer pivots on the arms.
The build pictures were on the Snail Forum, but that is no more.
He may be nearby you.
June 28th, 2020, 11:48 am
Crazy Belgian ? Needs some explanation this :o
June 28th, 2020, 4:37 pm
Zijn bijnaam is “Gek Belgisch”
See https://www.flickr.com/photos/46303217@N05/4256614525
June 28th, 2020, 5:04 pm
OK, now I understand. Thnks
June 28th, 2020, 6:17 pm
The sub-frame that I fabricated was not upto the job.
The top rail was bending when under full load.
Under examination the strange result is the the rail is now bent Upwards?
Revised Frame Build...
Steel 50x25x2.5 previous was 25x25x2.5
With a plan to add some corner gussets
August 20th, 2020, 2:24 pm
Finished and Painted sub frame @ 9kgs.
August 23rd, 2020, 12:21 pm
Shorter Struts.
Still need to add a top plate to retain the spring when he suspension droops.
Spring with insert and Spring Cover
Compressed.
Extended.
September 4th, 2020, 2:30 pm
Front Arm almost there...
September 10th, 2020, 1:21 pm
