View unanswered posts | View active topics It is currently April 27th, 2026, 4:59 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 89, 90, 91, 92, 93, 94, 95 ... 105  Next
 Make Your Own ....2CV.... 4x4
Have had thoughts about reaming the hole out, but the reamer size I can buy is 4.99mm
Thats leaves .01 mm which is still too much for a friction fit with hardened pins :( :?:
May 12th, 2019, 5:26 pm
Engine together with diff (gearbox) out of the car.
May 14th, 2019, 10:47 am
Before, During and After.
May 14th, 2019, 4:53 pm
Re-assembled the rear cover with Loctite gasket and then saw the bearing, missing one ball bearing!!!
Dismantled it all to check, all the other bearings are OK :D
The last bearing fits from the outside and is held in place by the oil seal cover. :D
Balls up!
May 21st, 2019, 12:36 pm
So let me get this right Pete,
you're one ball bearing short of a 2cv 4x4 :?: :)
May 21st, 2019, 7:31 pm
:lol: :lol:
ps
I found it on the floor!
May 21st, 2019, 8:42 pm
Mine was under the sofa!
May 21st, 2019, 8:56 pm
Front Diff(Gearbox) reassembled and ready to refit.
HOWEVER!
Have found the steering rack has a very nasty "clack" and is also to loose.
For me that is a real bummer to get under the car to remove and solve issue and refit, but the weather is good at the moment :)
May 22nd, 2019, 10:34 am
Had not tensioned the plunger correctly :(
ps
Sack the old fart that overlooked it :D
May 23rd, 2019, 11:10 am
Was it easily accessible?
May 23rd, 2019, 11:44 am
