View unanswered posts | View active topics It is currently June 19th, 2026, 12:32 pm
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 79, 80, 81, 82, 83, 84, 85 ... 105  Next
 Make Your Own ....2CV.... 4x4
Nothing fell over :( :D
October 22nd, 2017, 3:56 pm
The "spoilt" shaft for the front diff, has NOT yet be thrown in the scarp bin :o.
Will have to wait to end of next week to see if it can be used.
Being a person that plans everything and is very methodical in my approach to engineering, I found to my dismay the the rear diff has been assembled with the crown wheel on the wrong side :( :( .
So I have taken it out of the chassis, ready for a rebuild as and when the front diff is done.
October 27th, 2017, 3:34 pm
It's just as well the clocks go back this weekend then :lol:
October 27th, 2017, 6:43 pm
True, light but no warmth :(
October 27th, 2017, 8:57 pm
Some progress? and I hope I am not tempting fate this time with this post.
Additional issues after the "spoilt" pinion shaft.
Cannot successfully fit a 4speed diff in a 5 speed case?
Discovered that a LN diff is about 5mm smaller in diameter, it has 8/33 ratio, so I have machined the pinion shaft to allow the same special bearing to be fitted. Have to admit defeat on the threading,broke too many carbide inserts:(
Found got a company in Gloucester to thread the M24 onto a very hard shaft:)
Before and After.
In situ.
December 20th, 2017, 2:34 pm
As the weather is so Barmy ventured into the shed...
Bell Housing + Front diff + Transfer shaft.
Most of the parts! to be assembled into a working mechanism, just have to "remake" an oil seal carrier and blanking cover.
Discs and brake calipers also need to be added to the pile.
December 24th, 2017, 3:30 pm
Now all the "bits" are together to make a front diff and transfer shaft from clutch to remote gearbox.
https://youtu.be/AjEGTUFA4aU
All rotates but is very very tight, will see how soon it wears out or fails:(
January 14th, 2018, 5:23 pm
Spent the weekend fretting about the tight gears.
So I took a disciplined approach :) and assembled and tried each shaft/bearing in turn.
The last one was the input shaft/flange and was the culprit.
Can now turn the flange by hand and the diff rotates.
Yippee!!!!!.
January 15th, 2018, 4:03 pm
Unique, bet you can't wait to try it out :) .
January 15th, 2018, 7:07 pm
Rear Differential now rotates in the correct direction, to match the front.
https://youtu.be/BFK7YzvUGeY
January 17th, 2018, 2:37 pm
