View unanswered posts | View active topics It is currently June 19th, 2026, 6:03 pm
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 69, 70, 71, 72, 73, 74, 75 ... 105  Next
 Make Your Own ....2CV.... 4x4
Online
If I did a road version it would need titanium skid plates :lol: :lol:
March 1st, 2017, 10:02 am
Online
The back plate, 2 halves, alll lined up ready to be welded to the main gearbox case!!!!
Shortened Main Shaft.
Needs to be threaded to take a 20mm Nut, however a bastard of a job as the shaft is very hard :cry:
March 1st, 2017, 1:17 pm
Online
Now with M20 nut. :D
March 4th, 2017, 6:00 pm
2.5 or 1.5? Lathe screwcut? What cutting tool?
Spill the beans Pete!
March 4th, 2017, 11:59 pm
Online
M20 x 1.5, Tried to cut on the Lathe, it does Metric threads :D.
Broke the carbide inserts :oops:, the first pinion shaft I did was done successfully??
Rummaged through the die collection and I had a die, had to buy (ebay) a large die stock.
Turned the shaft down, it was a very rough finish.
Used the die to cut the thread looks OK and the nut fits nicely.
March 5th, 2017, 11:47 am
Fun and games, good result!
March 5th, 2017, 4:42 pm
Online
While the gearbox case is being welded, set my mind on the transfer shaft that runs at engine rpm and connects between the font diff housing and the remote 4 speed gearbox.
Found a couple of cheap Kawasaki drive shafts which are good to 9000+ rpm.
Splined parts fit the rear of the layshaft and the front of the layshaft, just need to be very carefully TIG welded.
Pics...
Shafts with splined parts
Overview
March 11th, 2017, 11:41 am
Online
Propellor Shafts Parts
March 16th, 2017, 3:37 pm
Online
Pile of Parts so far...
Waiting for the prop shafts parts and the output gear, all be TIG welded and need to make rear cover to hold the Lip seals.
March 24th, 2017, 5:43 pm
Online
Quality welding, thanks to Ian at Allisport Ltd.
March 26th, 2017, 11:52 am
Users browsing this forum: subarupete and 44 guests
