View unanswered posts | View active topics It is currently June 20th, 2026, 12:41 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 57, 58, 59, 60, 61, 62, 63 ... 105  Next
 Make Your Own ....2CV.... 4x4
Ride Height.
Going to try a simple limit switch with a LED indicator to show when the ride gets to its static height.
Limit Switch for the left side front Strut.
March 13th, 2016, 3:54 pm
Latest Aquisition - Myford Milling Machine.
March 22nd, 2016, 3:18 pm
Good choise.
March 22nd, 2016, 4:00 pm
First time REAL use of the Milling machine.
Milled the back of a gearbox....
More bigger bits to follow.....
March 26th, 2016, 4:25 pm
Milled the the gearbox flat, need to get the back welded on, and then get the shaft shortened.
Gearbox is about 9cm shorter.
The plan being..... to put a standard steering set up on the front, this stumpy gearbox will just fit, with the drive going under the cross tube.
Well thats the plan :?
March 29th, 2016, 12:06 pm
And after you have made some parts, you really get wondering how you managed without these machines... :lol:
March 29th, 2016, 12:26 pm
@Jasu, In the past have paid silly money to get things made, small machine shops are becoming extinct here, so DIY extends the budget, Its also very satisfying.
Made a dummy lay shaft, fitted the main shaft, with is new bearing, all aligned, ready to get it welded :o
March 30th, 2016, 4:22 pm
Very pleased with the welded gearbox, Thanks to Ian at http://www.allisport.com/
April 4th, 2016, 1:06 pm
Mock-up for Gearbox mounting using 2CV Engine mounts.
April 6th, 2016, 1:58 pm
Comparison of the two gearboxes.
Stumpy Version at the top, Standard 5 speed at the bottom.
April 7th, 2016, 12:23 pm
