View unanswered posts | View active topics It is currently July 15th, 2025, 1:19 am
Reply to topic  [ 3993 posts ]  Go to page Previous  1 ... 305, 306, 307, 308, 309, 310, 311 ... 400  Next
I managed to not do that for so many years and then did it last year. What a bloody mess..!
September 28th, 2015, 10:51 am
I cleaned the enginebay today. A lot of degreaser and a hot steamcleaner with shampoo did the trick.
September 28th, 2015, 9:29 pm
Mine passed the MOT without any issues, then broken down 2 miles out of the garage :shock:
1988 2CV Special
1969 Singer Chamois
October 8th, 2015, 2:39 pm
Not today, but Tuesday - bought one and brought it back to the UK.
Today I tried to restore a shine to some of the paintwork, but I reckon it'll be easier to repaint some of the panels!
October 8th, 2015, 6:27 pm
Pics?
October 8th, 2015, 7:45 pm
There's one in my avatar. I'll upload some more later.
It's later!
October 9th, 2015, 7:47 am
Very nice.....
October 9th, 2015, 7:08 pm
Nelsthebass wrote:
Very nice.....
+1
October 11th, 2015, 2:47 pm
Today I be mostly taking the body off as the MoT is due and there is a big hole where the L/h cill should be. Easier to tip the shell over I thought than the whole car. Glad I am that I did as there is a slight hole and rustiness showing on the toe board box section... :? Also, with the body on I can't get @ the rear dampers - these are friction ones - there is a seam on the shell that just prevents you getting the cover off the damper... Is this an original feature or is this the result of past rebuilds? The seam seems to be there on original (later) cars - not got another unmolested friction damper car to compare with - should it be hammered flat or was it always a problem, or where the panals different on earlier ones...?
Ta muchley
Mike
October 11th, 2015, 3:12 pm
took the windscreen out of the 57 as it was leaking. I thought to kit around the thing and put it back in.....nope, some rust under the rubber. And 2 little holes. The drainholes were blocked, i managed to open one the other still to do. So some anti-rust proofing to do.
October 11th, 2015, 4:42 pm
