Oil - Everywhere. Smoke too!
samfieldhouse
 Re: Oil - Everywhere. Smoke too!
dave 411 wrote: Maybe the bolt is bottoming out (too long)? Is there a gasket or seal that may have blown? Your nuts will be with you next week,tues/wed. Cheers  thank you!! Rekon its probably the gasket so Russell wrote: I'd tap it m8 and use a new gasket. is the way to go.
| May 21st, 2011, 9:51 am |
twofifty AZU
Have you done a compression test and made sure it hasn't snapped a ring?
I've got a big M4 reniflard if you want to try that.
| May 21st, 2011, 10:50 am |
Russell
I thought it might have got worn rings as it smokes like dot cotton. I don't have a compression tester unfortunately.
| May 21st, 2011, 10:59 am |
samfieldhouse
twofifty AZU wrote: Have you done a compression test and made sure it hasn't snapped a ring?
I've got a big M4 reniflard if you want to try that. Would that cause it to pee out of the filler gasket? Just tried to drive to work, but it was pouring out by the gasket that seals between the filler and crank case. I'll get a new gasket and go for the thread insert option. How do I do a compression test?
| May 21st, 2011, 11:01 am |
Neil
samfieldhouse wrote: How do I do a compression test? There's a thread on compression testing here: viewtopic.php?f=7&t=2789&hilit=compression+test
| May 21st, 2011, 11:13 am |
Russell
You want something like eBay item 250689979901.
| May 21st, 2011, 11:16 am |
twofifty AZU
If a ring is broken then the compression created as the piston goes up the bore leaks past the pistonj and pressurises the crank case. That in turn can cause the oil to leak out all over the place. The gasket between the crank case and rebiflard ought to withstand that though. Have you put a straight edge across the flange on the reniflard to see if it isn't warped? samfieldhouse wrote: twofifty AZU wrote: Have you done a compression test and made sure it hasn't snapped a ring?
| May 22nd, 2011, 1:31 am |
dave 411
Joined: August 19th, 2010, 10:44 pm Posts: 1815 Location: Cardiff
Whats a reniflard
_________________ [img]http://i1207.photobucket.com/albums/bb480/alastairsmith999/dave411-5.png[/im g]Horizontally Opposed
| May 22nd, 2011, 7:57 am |
ben
French for breather i believe The oil filler fandango with the pipe coming off to the airbox, bolts on the crank case with two bolts .
| May 22nd, 2011, 8:41 am |
dave 411
Ah,thanks
| May 22nd, 2011, 9:22 am |
Users browsing this forum: No registered users and 100 guests |
