Rear Diff with Reduction Gears.
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2257 Location: Near Monmouth
Progressing with building a light-weight Rear Diff with Reduction Gear and Selector. The prop shaft will run through the cabin. Attachment:
| May 5th, 2025, 2:59 pm |
subarupete
 Re: Rear Diff with Reduction Gears.
| May 8th, 2025, 9:14 am |
AZL57
nice job.
| May 8th, 2025, 10:47 pm |
Roger V
Awesome ...
| May 13th, 2025, 7:47 pm |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1205 Location: Magyarország
I am always amazed at how people can make or modify technical things . My son is the same way, often making a sketch of how it should be, the details are then in his head, or working out during construction .
| May 13th, 2025, 8:22 pm |
subarupete
Now its warmer Fabricated all the parts, now to final assembly? Attachment:
| February 23rd, 2026, 12:15 pm |
subarupete
Almost done, new shafts made, need heat traetment. Front Box. Attachment:
Rear Diff/Box Attachment:
ps Fakebook is easier to. use, just shiiiiiiiiiiiiiit.
| June 15th, 2026, 6:11 pm |
jasu
Joined: August 8th, 2012, 11:00 am Posts: 510 Location: Korpilahti, Finland
How about the weight? On my rear diff, with reduction gears, with disc brakes the scale said 27 kg...
Didn't check the weight without brakes, I should check but maybe next time it is out..?
| June 16th, 2026, 9:14 am |
subarupete
With brakes 28Kg , but cut down bellhousing, cut down input shaft and no syncro parts:)
| June 16th, 2026, 9:40 am |
jasu
My bellhouse is also cut, as much as possible. Not cut any other shafts, but input shaft a little bit. Some photos can find on my topic, if photos is possible to see. Thanks to photo bucket, photos are there but not sure if they are visible nowadays... I have them somewhere, need to upload them to another place to hotline them. Some day, some year..?
| June 16th, 2026, 12:15 pm |
Users browsing this forum: No registered users and 63 guests |
