View unanswered posts | View active topics It is currently June 19th, 2026, 7:08 pm
Reply to topic  [ 205 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 21  Next
 2011 24hr Snetterton
Post Re: 2011 24hr Snetterton
I spent ages painting that fan.
June 5th, 2011, 10:47 pm
I purposefully did a really crap job of painting the fan that's on there now so you can do it properly for us at Snet mate! ;)
June 5th, 2011, 10:48 pm
As always Jon many thanks great job - next one for us Croft
June 6th, 2011, 9:38 am
Jon,Simon.
If you havent already done so,change the steering arm bolts for M8 12.9 (allen head) if you go raking you'll find that 40mm and 50mm length often come with the correct length of shank for the arm.
The hub can be tapped out quite easily with the bearing in situ but you need a first and plug tap and go carefully using plenty cutting fluid/oil
the bolts need cut to the correct length so you get maximum thread engagement, despite the heat treatment making them feel like glass they cut with a sharp hacksaw.
clicky linky tingy
June 6th, 2011, 11:16 am
Hi Sean
I think we looked at that before, Jon over to you on this one - Sean is this something we can do at Croft when we are doing nothing for hours on end?
June 6th, 2011, 12:04 pm
yes and no.
possible , but if you pull the thread then its hub/arm change time which may well use up all your endless hours.
Ill send a set of bolts to Jon with his rubber plug when he sends me his postal address.
June 6th, 2011, 12:37 pm
thanks Sean
June 6th, 2011, 6:42 pm
Sean wrote:
yes and no.
Cheers Sean, PM heading your way Sean......
June 7th, 2011, 2:51 pm
I have been made aware of another team looking for mechanics and refuellers, pm me and I'll put you in touch.
June 7th, 2011, 10:12 pm
Ooh, PM on its way Russ.....................
Okay, I lied! ;) :lol:
June 7th, 2011, 11:17 pm
