View unanswered posts | View active topics It is currently November 20th, 2025, 4:53 pm
Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
 Suspension Arms
Haggis Muncher
Post Suspension Arms
Well, now that I have a slightly buggered arm, can anyone tell me if acad arms are different to 2cvs etc? Can I just swap a 2cv one on? or a whole front axle?
I'm sure I've heard in the past that they are different somehow, but cant remember what. Also, flicking through the cassis catalogue shows they sell a specifically acad arm, and another for all the rest.
April 8th, 2013, 1:06 am
Post Re: Suspension Arms
You'll need to fit a pair of 2cv arms, the attachment point for the knife edge is at a different distance (nearer on Acadiane) from the hub giving a different suspension rate.
April 8th, 2013, 8:44 am
If you fit 2cv arms, the drive plate and wheel bearing needs to be 2cv as well. Van bearings are bigger and won't fit, unless you move over the hub
April 8th, 2013, 8:48 am
Haggis Muncher
Interesting info, thanks chaps! Interestingly, those aren't any reasons I remember hearing before so it must have been something else I was thinking of.
I get the feeling it'll just be easier to source a proper arm. So is it a specific acad arm I need, or will any van arm do?
April 8th, 2013, 8:57 am
If Roy can't help or anybody else. I have a couple of used Acadyane arms in stock.
April 8th, 2013, 9:01 am
Ami6, ami8, acadyane arms are thicker then 2cv (about 1mm) So I wouldn't use 2cv arms........
Try to find original ACA arms (Vicking voluntered already.....)
April 8th, 2013, 12:15 pm
If the only problem with the existing arm is damage to the 'blocks' into which the damper mounting plate bolts are threaded, it's not that difficult to chop out the old ones and weld on some replacements, is it? :roll:
I'm sure Russell did this to convert a friction damper arm to hydraulic damper type...
April 8th, 2013, 2:26 pm
I made some triangular gussets and welded them either side of the blocks the damper plate mounts onto and retapped them m10. In an emergency I've used an acad arm in a 2cv with the outer acad driveshaft. It worked ok until I had a proper set made.
April 8th, 2013, 8:10 pm
Haggis Muncher
My welding ain't worth shit, to be honest, so i wouldn't trust it on something as important as the shock mount.
April 8th, 2013, 10:51 pm
you dont need to weld them - take them off buff off the tack welds at the back - take what's left of the bolt out and re tap to M10 - buy some M10 bolts and shakeproof washers, cut bolts down to size fit and forget.
if you need them welding find Panelbeaterpeter or bring them down here.
April 8th, 2013, 11:26 pm
