View unanswered posts | View active topics It is currently November 20th, 2025, 1:51 pm
Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Sticking Gearbox
Post Re: Sticking Gearbox
Tripyrenees wrote:
I can't make it to that one as our work season starts.
Do you know anyone that can do a full revision on mine. - I can be without it for a week or so.
You are welcome to ship the box to me (clean) It is a day job depending what needs doing.
Need to strip it down to find out. You need to find a transport company to deliver both ways
Cheers
Peter
April 1st, 2013, 9:51 pm
There is only one person I'd recommend
April 2nd, 2013, 11:13 am
2CViking wrote:
It is very risky business to install a used gear box without knowing its past. There is a reason why it was removed.
90%+ certainty that the reason is body/chassis rot. Given the speed with which a gearbox can be swapped, I'd always just try a believed-good used one first. BUT DEFINITELY NEW OIL. Drain it before you fit it, then new oil before starting, and a change-when-hot after a few hundred km.
April 2nd, 2013, 12:22 pm
Not true. I have around 20 425 gearboxes collected over the last 4 years. None of them were fit enough to simply stick clean oil in and off you go. They all had all sorts of problems needing fixing before running properly.
If one is brave to just stick another box in, at least remove the lid and rear cover. However if one doesn't know what to look for, it is pretty pointless.
April 2nd, 2013, 12:49 pm
I am going to take the lid off and take a good look and work out the operation so I know what is going on for myself.
Then I will try and figure out how to get the Box to 2CViking.
How much does just the box weigh I wonder :?
April 2nd, 2013, 3:28 pm
2CViking wrote:
Not true. I have around 20 425 gearboxes collected over the last 4 years. None of them were fit enough to simply stick clean oil in and off you go. They all had all sorts of problems needing fixing before running properly..
Seems you are collecting all the wrong gearboxes then!!!!! :lol: :lol: :lol: :lol: :lol: :lol:
You must pick out the good ones not the bad ones ;) ;) ;) ;) ;) ;)
Just fooling you....
April 2nd, 2013, 5:08 pm
Looks like I will be shipping my gearbox for repair. Cannot find anything obvious that is wrong (broken bits in the bottom of the box).
Think I have found the source of the oil in my clutch though - seems to have all exited through the top plate of the gear box. :? Hardly got any left in the box even though I filled it just last week. :o
QUESTION - anyone know the weight and dimensions of the gearbox for shipping :?: :?:
Cheers
Ian
April 7th, 2013, 5:15 pm
According to a previous post by Ken 23kg is the weight, I guess you will have to measure the box yourself :-)
April 7th, 2013, 5:54 pm
yeah, just got my first quote through for shipping - €220 :o :o
It would be cheaper to drive it there, stay over and drive back with it (all fixed :D :D )
April 7th, 2013, 6:10 pm
Wow! at lea if you take it yourself you know it wont get damaged plus you can look over Vikings shoulder and learn too!
April 7th, 2013, 6:22 pm
