View unanswered posts | View active topics It is currently August 13th, 2025, 9:39 am
Reply to topic  [ 147 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 15  Next
 1957 AZU - Ren?? II
Post Re: 1957 AZU - René II
Id work through the grades. Sand flat with 600 grade, 1000, then 1200.. Will be dead smooth then
March 18th, 2013, 11:44 pm
Spot on James I should have mentioned the grades :roll: If you want to get a really smooth uniform finish with no low spots and the like,if you give the area your doing a light spray over with a dark colour from an aerosol can,as you rub down any low spots will show up as the dark colour will remain. :mrgreen:
March 19th, 2013, 12:14 am
Also should of memtioned that too , seeing as i do it every day of the wek
March 19th, 2013, 9:11 am
So I painted the front of the car. :shock: Did it all in a day and it looks OK - I didn't bother doing all the filling etc as this was "purely" to cover up all the rusty primer the last guy put on (I did sand down to bare metal to get rid of the rust). I used 2 pack paint (as I had used a spray can of it and ran out so had to buy a 1kg tin of the same type). I am still alive but I can see why you need the mask etc (I did it outside so half the drive is the same colour as are the flies, wasps and dogs :lol: ).
Oh, and it is a different colour :lol: .... I know.... not a standard 2cv colour so it was hard to match at all. But it will all change in September when it goes back to the original colour. :)
BEFORE
AFTER
[ttachment=0]IMG_0727.jpg[/attachment]
March 20th, 2013, 1:57 pm
cracking job
March 20th, 2013, 3:03 pm
Very nice :-)
March 20th, 2013, 3:24 pm
Very nice indeed - nice to see the actual colour of your van! ;)
Overly Ambitious Project
March 20th, 2013, 5:27 pm
By the way what colour paint did you use - AC???????
March 20th, 2013, 6:08 pm
That was the issue - I had no clue and don't think this was a citroen colour. So I just went to the paint man and we used a chart.... must have been bad light as it is distinctively WRONG :oops:
March 20th, 2013, 6:16 pm
Still : Very Nice!
Good job.
March 20th, 2013, 6:25 pm
Users browsing this forum: Bing [Bot] and 19 guests
