View unanswered posts | View active topics It is currently May 1st, 2026, 11:32 pm
Reply to topic  [ 10 posts ]
 Engine trouble
Post Engine trouble
I got a free dyane engine a day ago, it is seized, the spark threads are stripped and the cylinders have dirt and rust packed in them. I also have a D*lly engine, which seems to be fine (havent started it, but i probably will). I'm pretty sure they are different compression, but could I use the heads from the D*lly engine on the dyane engine? or would you just use the tinwear from the dyane engine on the D*lly engine to create a 'replica'?
Cheers
March 16th, 2013, 9:42 pm
Post Re: Engine trouble
strip them all down and look at the mechanicals only the pistons are different oh and the tin ware you may find that nothing is useable
note if using the dyane blown engine you need a carb with the slightly larger jets.
March 16th, 2013, 9:55 pm
thanks, thats solved a big headache!
March 16th, 2013, 10:10 pm
get stripping jack!
sparkplug threads can be helicoiled btw
March 16th, 2013, 11:02 pm
:lol: i'll be in my shed tommorow then!
March 16th, 2013, 11:27 pm
The fan housing with turbo tube is up to you - but I'd definitely use the tin cylinder cowlings rather than the rubber.
March 17th, 2013, 12:23 am
yeah, although there is 'tin' underneath the rubber exterior. The rubber was put on by citroen as a soundproofing (i think).
March 17th, 2013, 12:42 am
Jack,
there's no tin underneath those recycled tyres on wolly engines.
They were also cheaper to make than metal cowlings... :roll:
March 17th, 2013, 1:29 am
oh right! everyday is a school day, It felt like there was tin underneath.
March 17th, 2013, 12:01 pm
as if by magic!
March 17th, 2013, 7:25 pm
Users browsing this forum: No registered users and 122 guests
