View unanswered posts | View active topics It is currently April 27th, 2026, 8:07 pm
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 28, 29, 30, 31, 32, 33, 34 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
Downloaded again on wifes windows 7 laptop exactly same with same errors
Boggy
March 11th, 2013, 9:47 pm
Post Re: 1-2-spark
Should there be advance table files included as I cant find them!!
March 11th, 2013, 9:53 pm
Post Re: 1-2-spark
I think there must be another program running on your pc that allows it to open tables which we dont have. I get an error message in a foreign language which I think says that a plugin is missing
Boggy
March 11th, 2013, 10:02 pm
Post Re: 1-2-spark
So kidnapped my wives laptop and got the same eror-message as you have so this is good :( :( :( :(
So here it is; the solution another little programm which enables the tables at least at my wifes laptop, 5 minits ago so must work at yours too...
SetupCXPlugIn_Tabelle_1017.zip
now its German, so you when you see this message you can choose NEIN
and go on (weiter).....
Now get it running guys....
March 11th, 2013, 10:42 pm
Post Re: 1-2-spark
It seems to have installed correctly, said to restart my PC so I did, but 1-2 spark program (38J/38L) still doesn't launch, I just get the error sound.
March 11th, 2013, 11:03 pm
Post Re: 1-2-spark
YES YES YES
downloaded plugin and ran it then ran original 1-2-spark 32j had blank table then imported table from advance table folder 8 degrees and BURN and all boxes filled with number 8 then tried next table and that worked too
well done lpgo
March 11th, 2013, 11:18 pm
Post Re: 1-2-spark
Oh and did not run the runtime program!
cheers
Boggy
March 11th, 2013, 11:19 pm
Post Re: 1-2-spark
Yes, Yes and Yes - it even loaded on my crappy Vista computer. Can see all the advance tables. Nice one Geo :D :D :D :D
March 11th, 2013, 11:22 pm
Post Re: 1-2-spark
Tried it on wifes pc and also worked fine...so thats Vista XP and windows7 all working ok...anyone tried on windows 8????
Boggy
March 11th, 2013, 11:26 pm
Post Re: 1-2-spark
Now can you figur out what these numbers mean.... I guess you do.....
Time to get the reel deal then.......
At the page settings you see the maplagfactor, this is to smoothen the mapnumbers coming from the unit....
I got 70% filled in here in my car; which means that the new reading from the
mapsensor - the last reading * .70 will be the new factor....
at 100 percent the new reading will be directly used for calculation
at 1 percent only 1% of the diffrence between the 2 readings will be added to the new reading so smoothing things out...
The mappressure fluctuates??? as air is sucked in stopped sucked in again aso....
Hope you understand now....
March 11th, 2013, 11:53 pm
Users browsing this forum: No registered users and 137 guests
