View unanswered posts | View active topics It is currently November 19th, 2025, 3:14 pm
Reply to topic  [ 10 posts ]
 Wheel bearings.
Post Wheel bearings.
By back right wheel bearing suddenly died in a spectacular fashion, I have found a replacement at 17mm wide rather than 27mm wide for £8.60. Is there a good reason not to put this in and hope it works?
The cheapest 27mm wide one I can find is £15.50
June 29th, 2009, 1:35 am
Post Re: Wheel bearings.
What is 17 and 27 mm wide?
Is it 2cv or van/ami bearings?
June 29th, 2009, 9:33 am
Old Bloke
Well that would explain why your car was not handling very well [see other posts re: car trying to kill me]
If you would like the car to try and kill you again fit any old wheel bearing. If you want to live long and prosper, fit the correct one.
To "hope" a component like a wheel bearing is going to work is like saying I hope I dont die if I stick my head on a railway line.
Be sensible. :evil:
Now known as 602
http://www.2CVTech.co.uk
June 29th, 2009, 11:03 am
Old Bloke
Just noticed you are a medical student, thats a bit worrying!!
Now known as 602
June 29th, 2009, 11:04 am
Be sensible. :evil:
I grabbed an old less shagged one from the shed and put that on instead, improving the handling notably, so it does seem to have been the root of the problem.
I normally try and do things properly but with a huge impending rent bill, and not enough to pay it, I'm scraping around for every penny.
I've found an industrial bearing supplier down the road I'll give a ring later and see if they have something more suitable at a lower price.
June 29th, 2009, 11:48 am
Old Bloke
Or you could save up and buy the real thing and save a life. The wheel could come off if the bearing fails. A wheel bouncing down the road could kill.
Now known as 602
June 29th, 2009, 11:59 am
Agree, don't fit any other bearings than correct ones. It is risky business.
If you can't afford it, leave the car at home until you can.
Happy ducking
June 29th, 2009, 12:08 pm
35x72x27 - it's the only size!
June 29th, 2009, 1:34 pm
Thats just stupid
and poverty no excuse as all that will happen is you waste £8.60 on a usless bearing then spend on a proper one as well :roll:
June 30th, 2009, 12:00 am
Not to mention the fact that it will invalidate your insurance if it's discovered after an incident occurs.
Sorry to gang up on you but a criminal conviction for that makes getting work in the NHS a wee bit difficult for at least six years and casts a serious doubt on your ability to make a correct judgement.
You are right about one thing though, local bearing specialists can often come up trumps. I use a local firm called Orbic Bearings and they're even able to supply the correct bearings for some of my sixty year old model aircraft engines :)
I should add that they're not necessarily cheaper than a certain excellent Staffs supplier. But they don't cost more and I often find there's an unnecessary but effectively free upgrade to the standard part plus there's no waiting or postage.
June 30th, 2009, 6:44 pm
Users browsing this forum: Google [Bot] and 11 guests
