View unanswered posts | View active topics It is currently May 2nd, 2026, 2:17 am
 Dead dash light
Post Dead dash light
Trying to help a friend with his mot
The dash light doesnt illuminate the speedo (mot fail)
Theres no power in the purple wire which is an live?? When the lights are on any setting...
What could the cause be? Checked all usual mickey mouse stuff (fuses etc)
Is this on the same circuit as the side lights as he has had problems with sidelights before...!!
Could i take a wire through from the switch or something to illuminate it?
Cheers
March 10th, 2013, 3:43 pm
Post Re: Dead dash light
If you can find the wire that does the side lights from the switch then join to this one and to the light - what about the earth on the light - is it OK?
March 10th, 2013, 4:22 pm
Tried earthing manually. Still no joy.
I geuss i need more time tools etc and some wire to sort it
Should i therefore make the wire that is inline with it on the fuel gauge also live? (Is that another light..?)
Cheers
March 10th, 2013, 4:29 pm
you could join it to the feed on the fuel guage for now
March 10th, 2013, 5:15 pm
Although its inline and also dead...
March 10th, 2013, 5:28 pm
Then you will need to join it to the new feed. Do not forget to tape the old feed just incase it become live in the future
March 10th, 2013, 5:35 pm
Ok
Is the purple wire a light behind the fuel gauge?
Since this car has been messed with before I don't feel too bad snipping the purple ended wire and taping the old dead wire up and wiring it up to the switch..
Ill try do that tomorrow ..
I guess a play with the multimeter will show me which wire the terminal needs to go onto..
March 10th, 2013, 5:42 pm
Tie a torch onto the gear stick ?
March 10th, 2013, 8:32 pm
Sadly wont pass the mot. Its not for comfort its for the mot man
March 10th, 2013, 9:02 pm
>Check the light bulb...
>Check the spring loaded bulb case... :|
I've Been Wrong Before.
March 11th, 2013, 11:28 am
Users browsing this forum: No registered users and 155 guests
