View unanswered posts | View active topics It is currently June 19th, 2026, 8:21 pm
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 25, 26, 27, 28, 29, 30, 31 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
Lpgo
Just pm'd you and then read your post
Id like to put my name on a unit pls :-)
Oh do you have idiot proof instructions???
March 8th, 2013, 12:25 am
Post Re: 1-2-spark
lpgo wrote:
This means they only need a logic level 5volt to trigger. Where does it gets it dwelltime from then????
And at last, please make a topic from your 2cv with lots of pics implementing Megasquirt, we are all hungry..........
THe coils I have, LS1, have inbuilt ignitors, does this explain it?
http://www.useasydocs.com/details/logic_level_spark.htm
Yes, I think it is time I opened a thread on my car, it is about to be reborn, again ;-)
March 8th, 2013, 1:28 pm
Post Re: 1-2-spark
So here it is; the first release of the newest software, with 12x12 advance/map-table
Before you run the programm you must run the 1-2-spark runtime.exe otherwise you can't open the tables......
Running the software "1-2-spark_38J.exe" you must choose "go offline" the software will open.
Going to the advance tab you can import 1 of the advancetables I included....
Now please let me now if it works....
March 9th, 2013, 11:15 pm
Post Re: 1-2-spark
Both files and advance tables downloaded to my computer. :) :) :)
Just to let you know after returned home last night - car has done 8000 kms with turbo and 1-2 SPARK :D :D :D
March 10th, 2013, 9:32 am
Post Re: 1-2-spark
Please let me now if you can open the table and import a advance table. Copy the tables at your desktop and push the import button in the software (at the advancetab) then search for the tables and if you find it open it...... now the advance numbers must appear in the table......... (you cant change them at the moment offline) but if you wish I can send a newer version of the software already!!!! Then you can change the number making your own table and export it to your computer......
So if you tune and your satisfied with your numbers you can export your table, go on with tuning and if it gets worse you can import the last good table..... clever hey 8-) 8-) 8-) 8-) 8-) 8-)
March 10th, 2013, 11:03 am
Post Re: 1-2-spark
Tried with Vista computer but nothing so placed it on my mates XP computer (the one that works with my car) and the program loaded OK. Found advance curves and imported one, then pressed burn and 1-2 spark said OK loaded. When I open advance - no table appears offline - should I connect to car???
March 10th, 2013, 3:57 pm
Post Re: 1-2-spark
Don't connect to your unit,
It won't work, numbers will be changed at wrong places..... but guess it would say no connection....
Did you see the table 12x12 and when you imported the table did you see the numbers in the screen?????
Did you run the runtime programm!!!!!
March 10th, 2013, 4:27 pm
Post Re: 1-2-spark
Hi ipgo will download tonight and let you know results on XP and windows 7
Cheers
Boggy
March 10th, 2013, 5:15 pm
Post Re: 1-2-spark
Would be a great help!!
March 10th, 2013, 6:11 pm
Post Re: 1-2-spark
Made video to show what was happening - loaded the driver first and after video turned off computer and re booted to see if it loaded. Same issues as video. (took 2 hours to upload to Youtube !!!!!)
March 10th, 2013, 8:18 pm
Users browsing this forum: No registered users and 215 guests
